CTB1202/3BK
CTB1202/3BK
    CAMDENBOSS
    Conn Terminal Block F 3 POS 5mm Solder ST Thru-Hole 16A
CTB1202/3BK 数据手册
5 mm Pitch Standard Profile Terminal Block zz 2 & 3 pole interlocking zz Test probe facility zz M oulded in black UL94V-0 PA (GF) zz Wire protector terminals zz  UL approved zz Guided pin alignment CTB1202 series CTB1202 Type No. Poles CTB1202/2 2 CTB1202/3 3 CTB1202/4 4 CTB1202/5 5 CTB1202/6 6 CTB1202/7 7 CTB1202/8 8 CTB1202/9 9 CTB1202/10 10 CTB1202/11 11 CTB1202/12 12 Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm Rating 250V/16A Insulation resistance 5000M Ω at 1000V Operating temperature -33°C to 120°C Cable entry 2mm² Withstand Voltage AC2000V/1Min Recommended PCB hole size ø1.3mm2 10mm Pitch Standard Profile Terminal Block CTB2202 series 10xP 0.6 9 Ø1.8 10 12.5 zz Test probe facility zz M oulded in black UL94V-0 PA (GF) zz Wire protector terminals zz  UL approved zz Guided pin alignment 2.5 10x(P-1) 10x(P-1) 2.5 4.5 Ø1 5 9 Rating 250V/16A Type No. Poles CTB2202/2 2 20mm -30°C to 120°C CTB2202/3 3 30mm Stainless Steel CTB2202/4 4 40mm Cable entry 2mm² CTB2202/5 5 50mm Withstand Voltage AC2000V/1Min CTB2202/6 6 60mm CTB2202/7 7 70mm CTB2202/8 8 80mm CTB2202/9 9 90mm CTB2202/10 10 100mm CTB2202/11 11 110mm CTB2202/12 12 120mm Insulation resistance Operating temperature Wire Protector Recommended PCB hole size 5000M Ω at 1000V ø1.3mm Length Tel: +44 (0)1638 716101 Fax: +44 (0)1638 716554 E-mail: camdeninfo@camdenelec.com Website: www.camdenelec.com E-mail: enquiry@boss-enclosures.co.uk Web: www.boss-enclosures.co.uk Because we operate a constant improvement policy, our products are subject to change without notice. FM28614 BS EN ISO 9001: 2000
CTB1202/3BK 价格&库存
很抱歉,暂时无法提供与“CTB1202/3BK”相匹配的价格&库存,您可以联系我们找货
