CTB1302/PS24
CTB1302/PS24
    CAMDENBOSS
    CAMDENBOSS - CTB1302/PS24 - Connector Accessory, Pin Strip Header, Camdenboss CTB1302 Series PCB Ter...
CTB1302/PS24 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS ECONOMY RANGE 5mm pitch pluggable terminal blocks for vertical or 90˚ mounting Product overview • 2 & 3 pole interlocking • Moulded in black UL94-V0 PA66 flame retardant PA66 • Wire protector terminals • Captive screws • 0.33-2mm2 (22-14AWG) • Guided pin alignment • approved PA R T N O . POLES LENGTH CTB1302/2 2 10mm CTB1302/3 3 15mm CTB1302/4 4 20mm CTB1302/5 5 25mm CTB1302/6 6 30mm CTB1302/7 7 35mm CTB1302/8 8 40mm CTB1302/9 9 45mm CTB1302/10 10 50mm CTB1302/11 11 55mm CTB1302/12 12 60mm S P E C I F I C AT I O N Rating 10A 250V Insulation resistance 5000M Ω/1000V Withstand voltage AC1500V/1min Contact resistance 20m Ω Working temperature -33°C to +120°C Mouldings UL94-V0 flame retardant PA66 Terminal Tin plated brass Wire protector Tin plated copper Screw/torque M2.5 steel, nickel plated 0.4Nm CTB1302 13.6 13.6 5mm pitch 24 pin strip header 23 • 2 & 3 pole interlocking • Moulded in black UL94-V0 PA66 flame retardant PA66 • Wire protector terminals • Captive screws • 0.33-2mm2 (22-14AWG) • Guided pin alignment • approved 24 5000M Ω/1000V Withstand Voltage AC1500V/1min Contact Resistance 20m Ω Working Temperature -33°C to +120°C Mouldings UL94-V0 flame retardant PA66 Pin Stainless steel Recommended PCB hole size ø1.6mm Screw/torque M2.5 steel, nickel plated 0.4Nm CTB1302/PS 8.25 POLES CTB9502/2 10A 250V Insulation resistance 4.0 12.5 PA R T N O . S P E C I F I C AT I O N Rating 2.25 E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS Product overview 2.85 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CTB1302/PS24 价格&库存
很抱歉,暂时无法提供与“CTB1302/PS24”相匹配的价格&库存,您可以联系我们找货
