PCB TERMINAL BLOCKS
PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
5.08mm Pitch Pluggable Rising Clamp Terminal Blocks
• 2
-24 pole solid block
• Pluggable male-female
connectors
• Open & closed headers
• Horizontal & vertical
female plug styles
• Polarised mouldings
• Moulded in green UL94-V0
flame retardant PA
• Professional rising
clamp terminals
• 0.2-2.5mm2 (30-12AWG)
solid & stranded cable
• Anti solder wicking
• Captive screws
• Guided pin alignment
approved
SPECIFICATION
Rating
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
12A/320V
UL=12A/300V, VDE&IMQ=20A/320V
≥2.5kV
4kV
110°C
UL94-V0 flame retardant PA
Copper alloy, NI & SN
M3 steel zinc plated, 0.5Nm
ø1.4mm
LEDs &
INDICATORS
Female connector
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
TYPE NO.
CTB9208/2
CTB9208/3
CTB9208/4
CTB9208/5
CTB9208/6
CTB9208/7
CTB9208/8
CTB9208/9
CTB9208/10
CTB9208/11
CTB9208/12
CTB9208/13
POLES
2
3
4
5
6
7
8
9
10
11
12
13
LENGTH
10.2mm
15.2mm
20.3mm
25.4mm
30.5mm
35.6mm
40.6mm
45.7mm
50.8mm
55.9mm
61mm
66mm
TYPE NO.
CTB9208/14
CTB9208/15
CTB9208/16
CTB9208/17
CTB9208/18
CTB9208/19
CTB9208/20
CTB9208/21
CTB9208/22
CTB9208/23
CTB9208/24
POLES
14
15
16
17
18
19
22
23
24
LENGTH
71.1mm
76.2mm
81.3mm
86.4mm
91.4mm
96.5mm
101.6mm
106.7mm
111.8mm
116.8mm
121.9mm
POLES
14
15
16
17
18
19
22
23
24
LENGTH
71.1mm
76.2mm
81.3mm
86.4mm
91.4mm
96.5mm
101.6mm
106.7mm
111.8mm
116.8mm
121.9mm
POLES
14
15
16
17
18
19
22
23
24
LENGTH
71.1mm
76.2mm
81.3mm
86.4mm
91.4mm
96.5mm
101.6mm
106.7mm
111.8mm
116.8mm
121.9mm
CTB9208
Female connector vertical (standard)
TYPE NO.
CTB92VJ/2S
CTB92VJ/3S
CTB92VJ/4S
CTB92VJ/5S
CTB92VJ/6S
CTB92VJ/7S
CTB92VJ/8S
CTB92VJ/9S
CTB92VJ/10S
CTB92VJ/11S
CTB92VJ/12S
CTB92VJ/13S
POLES
2
3
4
5
6
7
8
9
10
11
12
13
LENGTH
10.2mm
15.2mm
20.3mm
25.4mm
30.5mm
35.6mm
40.6mm
45.7mm
50.8mm
55.9mm
61mm
66mm
TYPE NO.
CTB92VJ/14S
CTB92VJ/15S
CTB92VJ/16S
CTB92VJ/17S
CTB92VJ/18S
CTB92VJ/19S
CTB92VJ/20S
CTB92VJ/21S
CTB92VJ/22S
CTB92VJ/23S
CTB92VJ/24S
CTB92VJ/S
BATTERIES
Female connector vertical (reversed)
SOLAR
PANELS
TRANSFORMERS
TYPE NO.
CTB92VJ/2R
CTB92VJ/3R
CTB92VJ/4R
CTB92VJ/5R
CTB92VJ/6R
CTB92VJ/7R
CTB92VJ/8R
CTB92VJ/9R
CTB92VJ/10R
CTB92VJ/11R
CTB92VJ/12R
CTB92VJ/13R
POLES
2
3
4
5
6
7
8
9
10
11
12
13
LENGTH
10.2mm
15.2mm
20.3mm
25.4mm
30.5mm
35.6mm
40.6mm
45.7mm
50.8mm
55.9mm
61mm
66mm
TYPE NO.
CTB92VJ/14R
CTB92VJ/15R
CTB92VJ/16R
CTB92VJ/17R
CTB92VJ/18R
CTB92VJ/19R
CTB92VJ/20R
CTB92VJ/21R
CTB92VJ/22R
CTB92VJ/23R
CTB92VJ/24R
CTB92VJ/R
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
很抱歉,暂时无法提供与“CTB9208/12”相匹配的价格&库存,您可以联系我们找货
