CTB9550/2
CTB9550/2
    CAMDENBOSS
CTB9550/2 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS 7.5mm & 7.62mm Pitch Pluggable Rising Clamp Terminal Blocks • 2-12 pole solid block • Pluggable male-female connectors • Open & closed headers • Horizontal female plug style • Polarised mouldings • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-2.5mm2 (30-12AWG) solid & stranded cable • Anti solder wicking • Captive screws • Guided pin alignment • , , approved SPECIFICATION Rating Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size 20A/500V UL=12A/300V, VDE&IMQ=20A/500V ≥3kV 6kV 110°C UL94-V0 flame retardant PA Copper alloy, NI & SN Copper alloy, NI & SN M3 steel zinc plated, 0.5Nm ø1.4mm LEDs & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN DIN RAIL RAIL ENCLOSURES ENCLOSURES PCB mounting male vertical (closed ended) 7.5mm 7.62mm TYPE NO. CTB9500/2 CTB9500/3 CTB9500/4 CTB9500/5 CTB9500/6 CTB9500/7 CTB9500/8 CTB9500/9 CTB9500/10 CTB9500/11 CTB9500/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 15mm 22.5mm 30mm 37.5mm 45mm 52.5mm 60mm 67.5mm 75mm 82.5mm 90mm TYPE NO. CTB9508/2 CTB9508/3 CTB9508/4 CTB9508/5 CTB9508/6 CTB9508/7 CTB9508/8 CTB9508/9 CTB9508/10 CTB9508/11 CTB9508/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 15.2mm 22.8mm 30.4mm 38.1mm 45.7mm 53.3mm 60.9mm 68.6mm 76.2mm 83.8mm 91.4mm CTB9500 PCB mounting male horizontal (closed ended) 7.5mm 7.62mm TYPE NO. CTB9550/2 CTB9550/3 CTB9550/4 CTB9550/5 CTB9550/6 CTB9550/7 CTB9550/8 CTB9550/9 CTB9550/10 CTB9550/11 CTB9550/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 15mm 22.5mm 30mm 37.5mm 45mm 52.5mm 60mm 67.5mm 75mm 82.5mm 90mm TYPE NO. CTB9558/2 CTB9558/3 CTB9558/4 CTB9558/5 CTB9558/6 CTB9558/7 CTB9558/8 CTB9558/9 CTB9558/10 CTB9558/11 CTB9558/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 15.2mm 22.8mm 30.4mm 38.1mm 45.7mm 53.3mm 60.2mm 68.5mm 76.2mm 83.8mm 91.4mm CTB9550 BATTERIES SOLAR TRANSPANELS FORMERS TRANSFORMERS 56 Ver Ver1.0 1.2 We operate a constant improvement policy, We operate a constant improvement policy, We operate a constant improvement our products are subject to change withoutpolicy, notice. our products are subject to change without notice. our products are subject to change without notice. (0)1638 716101 +44+44 (0)1638 716101 +44 (0)1638 716101 info@camdenboss.com info@camdenboss.com info@camdenboss.com www.camdenboss.com www.camdenboss.com www.camdenboss.com PCB TERMINAL BLOCKS PCB mounting male vertical (open ended) 7.5mm TYPE NO. CTB9500/2AO CTB9500/3AO CTB9500/4AO CTB9500/5AO CTB9500/6AO CTB9500/7AO CTB9500/8AO CTB9500/9AO CTB9500/10AO CTB9500/11AO CTB9500/12AO POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 13mm 20.5mm 28mm 35.5mm 43mm 50.5mm 58mm 65.5mm 73mm 80.5mm 88mm 7.62mm TYPE NO. CTB9508/2AO CTB9508/3AO CTB9508/4AO CTB9508/5AO CTB9508/6AO CTB9508/7AO CTB9508/8AO CTB9508/9AO CTB9508/10AO CTB9508/11AO CTB9508/12AO CTB9500/A0 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 13.2mm 20.9mm 28.5mm 36.1mm 43.7mm 51.3mm 59mm 66.6mm 74.2mm 81.8mm 89.4mm PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS PCB mounting male horizontal (open ended) 7.5mm 7.62mm TYPE NO. CTB9550/2AO CTB9550/3AO CTB9550/4AO CTB9550/5AO CTB9550/6AO CTB9550/7AO CTB9550/8AO CTB9550/9AO CTB9550/10AO CTB9550/11AO CTB9550/12AO POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 13mm 20.5mm 28mm 35.5mm 43mm 50.5mm 58mm 65.5mm 73mm 80.5mm 88mm TYPE NO. CTB9558/2AO CTB9558/3AO CTB9558/4AO CTB9558/5AO CTB9558/6AO CTB9558/7AO CTB9558/8AO CTB9558/9AO CTB9558/10AO CTB9558/11AO CTB9558/12AO POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 13.2mm 20.9mm 28.5mm 36.1mm 43.7mm 51.3mm 59mm 66.6mm 74.2mm 81.8mm 89.4mm MINIATURE SWITCHES CTB9550/A0 LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 +44 (0)1638 716101 info@camdenboss.com info@camdenboss.com www.camdenboss.com www.camdenboss.com Ver 1.1 We operate a constant improvement policy, products are subject to change without Weour operate a constant improvement policy, notice. Ver 1.0 our products are subject to change without notice. 57
CTB9550/2 价格&库存
很抱歉,暂时无法提供与“CTB9550/2”相匹配的价格&库存,您可以联系我们找货
