P C B T E R M I N A L B LO C KS
S TA N D A R D
PLUGGABLES
SCREWLESS
002
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
5.08mm pitch standard profile
rising clamp terminal blocks
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
CTBP0108
• 2 and 3 pole double interlocking mechanism
for increased strength
• Moulded in green UL94-V0 flame retardant
PA
• Cable acceptance - 0.3-3.31mm2 (22-12AWG)
• Professional rising clamp terminals
• Guided pin alignment
• Captive screws
• C
US approved
151
IP68 CONNECTORS
10.16mm
Insulation resistance
500MΩ / 500V
CTBP0108/3
3
15.24mm
Withstand voltage
AC1600V / 1min
CTBP0108/4
4
20.32mm
Contact resistance
20mΩ (max)
CTBP0108/5
5
25.4mm
Working temperature
-40°C to +105°C
CTBP0108/6
6
30.48mm
Moulding
UL94-V0 flame retardant PA
CTBP0108/7
7
35.56mm
Pin/terminal
Tin plated brass
CTBP0108/8
8
40.64mm
Rising clamp
Nickel plated brass
CTBP0108/9
9
45.72mm
Screw/torque
M2.5 steel, zinc plated / 0.4Nm
CTBP0108/10
10
50.8mm
Recommended PCB
hole size
Ø1.5mm
CTBP0108/11
11
55.88mm
CTBP0108/12
12
60.96mm
Ø1.50
10.50
2
5.00
LENGTH
CTBP0108/2
3.14 5.08
5.08(xx-1)
0.60
PCB layout
0.80
5.00
Section: A-A
K E Y F E AT U R E S
| Rising clamp terminals
CONNECT
Standard profile | Double interlock mechanism
34
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 12
Vers
5.08xx
A
3.50±0.3
INTERFACE
MODULES AND
RELAY BASES
POLES
16A / 300V
0.60
14.10
158
PA R T N O .
Rating
10.20
S P E C I F I C AT I O N
0.90
3.14
A
5.08
5.08(xx-1)
很抱歉,暂时无法提供与“CTBP0108/3”相匹配的价格&库存,您可以联系我们找货
