CTBP0150/3
CTBP0150/3
    CAMDENBOSS
    Conn Terminal Block F 3 POS 5mm Solder RA Thru-Hole 16A
CTBP0150/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES CTBP0150 • 2 and 3 pole double interlocking mechanism for increased strength • Professional rising clamp terminals • Standard profile 90° mounting • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.6-2mm2 (22-12AWG) • Guided pin alignment • C approved US , S P E C I F I C AT I O N PA R T N O . POLES LENGTH Rating UL=16A/300V, VDE=20A/250V CTBP0150/2 2 10mm Insulation resistance 500M Ω/500V CTBP0150/3 3 15mm Withstand voltage AC2000V/1min CTBP0150/4 4 20mm 20mΩ (max) CTBP0150/5 5 25mm -40°C to +105°C CTBP0150/6 6 30mm Moulding UL94-V0 flame retardant PA66 CTBP0150/7 7 35mm Pin/terminal Tin plated brass CTBP0150/8 8 40mm CTBP0150/9 9 45mm CTBP0150/10 10 50mm CTBP0150/11 11 55mm CTBP0150/12 12 60mm Contact resistance Working temperature Rising clamp Screw/torque Recommended PCB hole size Brass, nickel plated M2.5 steel, zinc plated 0.4Nm ø1.5mm 0.9 10.2 TERMINAL STRIPS 0.6 14.1 081 5mm pitch standard profile 90° rising clamp terminal blocks 0.8 PCB TERMINAL BLOCKS 4.6 K E Y F E AT U R E S CONNECT Professional rising clamp | Double interlock mechanism 24 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 | Standard profile
CTBP0150/3 价格&库存
很抱歉,暂时无法提供与“CTBP0150/3”相匹配的价格&库存,您可以联系我们找货
