SCREWLESS
PLUGGABLES
S TA N D A R D
P C B T E R M I N A L B LO C KS
002
PCB TERMINAL
BLOCKS
5mm pitch low profile rising clamp
terminal blocks
Product overview
081
TERMINAL STRIPS
CTBP0500
• 2 and 3 pole double interlocking mechanism
for increased strength
• Professional rising clamp terminals
• Low profile
• Moulded in green UL94-V0 flame retardant
PA66
• Cable acceptance - 0.6-1.3mm2 (22-16AWG)
• Guided pin alignment
• C
approved
US ,
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
POLES
LENGTH
Rating
UL=8A/300V, VDE=15A/250V
CTBP0500/2
2
10mm
Insulation resistance
500M Ω/500V
CTBP0500/3
3
15mm
Withstand voltage
AC2000V/1min
CTBP0500/4
4
20mm
Contact resistance
20mΩ (max)
CTBP0500/5
5
25mm
Working temperature
-40°C to +105°C
CTBP0500/6
6
30mm
Moulding
UL94-V0 flame retardant PA66
CTBP0500/7
7
35mm
Pin/terminal
Tin plated brass
CTBP0500/8
8
40mm
Rising clamp
Brass, nickel plated
CTBP0500/9
9
45mm
CTBP0500/10
10
50mm
Screw/torque
M2.5 steel, zinc plated 0.4Nm
Recommended PCB
hole size
ø1.3mm
CTBP0500/11
11
55mm
CTBP0500/12
12
60mm
IP68 CONNECTORS
8.5
PA R T N O .
158
0.6
INTERFACE
MODULES AND
RELAY BASES
10.2
S P E C I F I C AT I O N
0.9
4
4
0.6
5
K E Y F E AT U R E S
| Low profile
CONNECT
Professional rising clamp | Double interlock mechanism
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
19
很抱歉,暂时无法提供与“CTBP0500/2”相匹配的价格&库存,您可以联系我们找货
