CTBP96HJ/8FL
CTBP96HJ/8FL
    CAMDENBOSS
    CAMDENBOSS - CTBP96HJ/8FL - Wire-To-Board Terminal Block, Inverted, Flanged, 5.08 mm, 8 Ways, 28 AWG...
CTBP96HJ/8FL 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 5 .0 8 m m i nve r te d /reve r s e te r m i n a l blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS • • • • • • • • • • S P E C I F I C AT I O N 2-12 pole solid block Professional rising clamp terminals Moulded in green UL94-V0 flame retardant PA 66 Cable acceptance - 0.32 to 1.6mm2 (28-14AWG) Horizontal and vertical orientations Pluggable male and female connectors Polarized moulding Dual row pins for extra stability Also available in 5mm pitch US approved C 151 Rating UL=15A/300V Insulation resistance 500M Ω/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Rising clamp Brass, nickel plated Screw/torque M3 steel, zinc plated 0.5Nm Recommended PCB hole size ø1.4mm IP68 CONNECTORS Male connector PA R T N O . POLES LENGTH CTBP96HJ/2 2 11.8mm CTBP96HJ/3 3 16.8mm CTBP96HJ/4 4 21.9mm CTBP96HJ/5 5 27.0mm CTBP96HJ/6 6 32.1mm CTBP96HJ/7 7 37.2mm CTBP96HJ/8 8 42.2mm CTBP96HJ/9 9 47.3mm CTBP96HJ/10 10 52.4mm CTBP96HJ/11 11 57.5mm CTBP96HJ/12 12 62.6mm CTBP96HJ 5.08 8.6 19.30 INTERFACE MODULES AND RELAY BASES 9.4 158 15.2 Male connector (flanged) LENGTH A LENGTH B CTBP96HJ/2FL 2 11.8mm 20.3mm CTBP96HJ/3FL 3 16.8mm 25.4mm CTBP96HJ/4FL 4 21.9mm 30.5mm CTBP96HJ/5FL 5 27mm 35.6mm CTBP96HJ/6FL 6 32.1mm 40.7mm CTBP96HJ/7FL 7 37.2mm 45.7mm CTBP96HJ/8FL 8 42.2mm 50.8mm CTBP96HJ/9FL 9 47.3mm 55.9mm CTBP96HJ/10FL 10 52.4mm 61.0mm CTBP96HJ/11FL 11 57.5mm 66.1mm CTBP96HJ/12FL 12 62.6mm 71.1mm B CTBP96HJ FL A 5.08 5.08 5.08 8.60 19.30 POLES 9.40 PA R T N O . 15.20 72 CTBP97VJ/2 2 12.2mm CTBP97VJ/3 3 17.2mm CTBP97VJ/4 4 22.3mm CTBP97VJ/5 5 27.4mm CTBP97VJ/6 6 32.5mm CTBP97VJ/7 7 37.6mm CTBP97VJ/8 8 42.6mm CTBP97VJ/9 9 47.7mm CTBP97VJ/10 10 52.8mm CTBP97VJ/11 11 57.9mm CTBP97VJ/12 12 63.0mm CTBP97VJ +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 10.2 4 8.3 LENGTH 19 POLES 8.5 PA R T N O . 5.08 3.6 CONNECT PCB mounted female vertical connector 5.08 1.36 SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS PCB mounting female vertical connector (flanged) CTBP97VJ/2FL 2 10.2mm 20.32mm CTBP97VJ/3FL 3 15.2mm 25.4mm CTBP97VJ/4FL 4 20.3mm 30.48mm CTBP97VJ/5FL 5 25.4mm 35.56mm CTBP97VJ/6FL 6 30.5mm 40.64mm CTBP97VJ/7FL 7 35.6mm 45.72mm CTBP97VJ/8FL 8 40.6mm 50.8mm CTBP97VJ/9FL 9 45.7mm 55.88mm CTBP97VJ/10FL 10 50.8mm 60.96mm CTBP97VJ/11FL 11 55.9mm 66.04mm CTBP97VJ/12FL 12 61.0mm 71.12mm CTBP97VJ FL 5.08 5.08 081 TERMINAL STRIPS 10.2 A 4 8.3 LENGTH B 5.08 5.08 1.36 151 3 17.2mm CTBP97HJ /4 4 22.3mm CTBP97HJ /5 5 27.4mm CTBP97HJ /6 6 32.5mm CTBP97HJ /7 7 37.6mm CTBP97HJ /8 8 42.6mm CTBP97HJ /9 9 47.7mm CTBP97HJ /10 10 52.8mm CTBP97HJ /11 11 57.9mm CTBP97HJ /12 12 63.0mm 5.08 158 INTERFACE MODULES AND RELAY BASES 10.2 8.3 CTBP97HJ /3 CTBP97HJ 1.1 5.08 12.2mm 19 LENGTH 2 IP68 CONNECTORS 8.5 POLES CTBP97HJ /2 100 CIRCULAR CONNECTORS B PCB mounting female horizontal connector PA R T N O . 095 WIRE TO BOARD CONNECTORS 19 LENGTH A 3.6 POLES 8.5 PA R T N O . PCB mounting female horizontal connector (flanged) 10.2mm 20.32mm CTBP97HJ/3FL 3 15.2mm 25.4mm CTBP97HJ/4FL 4 20.3mm 30.48mm CTBP97HJ/5FL 5 25.4mm 35.56mm CTBP97HJ/6FL 6 30.5mm 40.64mm CTBP97HJ/7FL 7 35.6mm 45.72mm CTBP97HJ/8FL 8 40.6mm 50.8mm CTBP97HJ/9FL 9 45.7mm 55.88mm CTBP97HJ/10FL 10 50.8mm 60.96mm CTBP97HJ/11FL 11 55.9mm 66.04mm CTBP97HJ/12FL 12 61.0mm 71.12mm 5.08 5.08 5.08 10.2 A B CONNECT 2 2.8 5.08 CTBP97HJ/2FL CTBP97HJ FL 8.3 LENGTH B 19 LENGTH A 8.5 POLES 2.8 PA R T N O . +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 73
CTBP96HJ/8FL 价格&库存
很抱歉,暂时无法提供与“CTBP96HJ/8FL”相匹配的价格&库存,您可以联系我们找货
