CTSN433/12/F
CTSN433/12/F
    CAMDENBOSS
CTSN433/12/F 数据手册
TERMINAL STRIPS 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 12 way nylon terminal strips 081 TERMINAL STRIPS Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS S P E C I F I C AT I O N • Moulded from: Voltage Natural PA6 (standard, CTSN400) Working temperature Cream PA66 (CTSN500) Grey PA66 glass fibre (CTSN600) • Available with or without wire protection Moulding • Passes 960°C glow-wire test according to EN 60695-2-11 Standard insert • Printing available on request Terminal screws • Easily cut to size Wire protectors • Supplied cut to length on request • Closed inserts (middle barrier) option CTSN400 • Captive terminal screws • C , , approved US , CTSN431-433 CTSN434-438 450VAC 750VAC (UL600VAC) CTSN400 CTSN500 CTSN600 -30°C to +110°C -30°C to +110°C -30°C to +160°C CTSN400 CTSN500 CTSN600 UL94-V2 PA6 UL94-V0 PA66 UL94-V0 PA66 + GF Nickel-plated brass Zinc-plated steel CQ-15 Stainless steel CTSN500 raised base Part Numbers shown are for standard PA6 material (e.g. CTSN433/12) 158 INTERFACE MODULES AND RELAY BASES For CSTN500 PA66 material change first number to 5 (e.g. CTSN533/12) For CSTN600 PA66+GF material change first number to 6 (e.g. CTSN633/12) Standard type PA R T N O . WIRE PROTECTION INSERT DIAMETER CABLE A C C E P TA N C E TERMINAL SCREWS LENGTH W I DT H HEIGHT PITCH FIXING HOLE DIAMETER MAX CURRENT UL R AT I N G CTSN431/12W No 3.2mm 4.0mm2/12AWG M3 94mm 18mm 15mm 8mm 2.8mm 32A 20A CTSN431/12 Yes 3.2mm 2.5mm2/14AWG M3 94mm 18mm 15mm 8mm 2.8mm 24A 15A CTSN433/12W No 3.5mm 2 M3 116mm 21mm 16mm 10mm 2.8mm 41A 30A 2 6.0mm /10AWG CTSN433/12 Yes 3.5mm 4.0mm /12AWG M3 116mm 21mm 16mm 10mm 2.8mm 32A 20A CTSN434/12W No 4.4mm 10.0mm2/8AWG M3.5 140mm 23mm 18mm 12mm 2.8mm 57A 50A 2 CTSN434/12 Yes 4.4mm 6.0mm /10AWG M3.5 140mm 23mm 18mm 12mm 2.8mm 41A 30A CTSN435/12W No 6.0mm 16.0mm2/6AWG M4 159mm 26mm 22.5mm 14mm N/A 76A 65A CTSN435/12 Yes 6.0mm 2 M4 159mm 26mm 22.5mm 14mm N/A 57A 65A M5 177mm 31mm 27.5mm 15mm N/A 125A 85A CTSN438/12W No 7.5mm 10.0mm /8AWG 2 35mm /2AWG Standard type, no wire protection L W P CONNECT H 96 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 2 1 FM 28614 EMS 613558 Vers 2 TERMINAL STRIPS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES Raised base PITCH MAX CURRENT UL R AT I N G 17mm 8mm 2.8mm 32A 20A 18mm 17mm 8mm 2.8mm 24A 20A 21mm 17.5mm 10mm 2.8mm 41A 30A PA R T N O . INSERT DIAMETER CABLE A C C E P TA N C E TERMINAL SCREWS LENGTH W I DT H HEIGHT CTSN431/12WR No 3.2mm 4.0mm2/12AWG M3 94mm 18mm CTSN431/12R Yes 3.2mm 2.5mm2/14AWG M3 94mm CTSN433/12WR No 3.5mm 6.0mm2/10AWG M3 116mm 2 081 FIXING HOLE DIAMETER WIRE PROTECTION CTSN433/12R Yes 3.5mm 4.0mm /12AWG M3 116mm 21mm 17.5mm 10mm 2.8mm 32A 30A CTSN434/12WR No 4.4mm 10.0mm2/8AWG M3.5 140mm 23mm 20mm 12mm 2.8mm 57A 50A CTSN434/12R Yes 4.4mm 6.0mm /10AWG M3.5 140mm 23mm 20mm 12mm 2.8mm 41A 50A CTSN435/12WR No 6.0mm 16.0mm2/6AWG M4 159mm 26mm 26mm 14mm 3.6mm 76A 65A CTSN435/12R Yes 6.0mm 10.0mm2/8AWG M4 159mm 26mm 26mm 14mm 3.6mm 57A 65A 2 TERMINAL STRIPS 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 118 IP68 CONNECTORS Raised base types - provides increased isolation L W 158 P INTERFACE MODULES AND RELAY BASES H 3 K E Y F E AT U R E S | V0 types meet 960°C GWT CONNECT V2 or V0 material | Easily cut to required size +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 2.31 Vers 97 TERMINAL STRIPS 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES Pluggable terminal strips 081 TERMINAL STRIPS Product overview 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES 450V AC Working temperature -30°C to +110°C (PA6.6 to +150°C) Moulding UL94-V2 self extinguishing PA6 Conducting bush Nickel-plated brass Terminal screws Zinc-plated steel Standard type PA R T N O . PITCH/ UL R AT I N G INSERT DIAMETER CABLE A C C E P TA N C E TERMINAL SCREWS LENGTH W I DT H HEIGHT PITCH FIXING HOLE DIAMETER MAX CURRENT CTSN431/12MF 8mm/6A 2.9mm 4.0mm2/12AWG M3 94mm 16mm 15.5mm 8mm 2.75mm 17.5A CTSN433/12MF 10.25mm/10A 3.4mm 2.5mm2/14AWG M3 119.4mm 20.5mm 16.4mm 10.25mm 3.2mm 24A CTSN434/12MF 12.5mm/16A 4.3mm 6.0mm2/10AWG M3.5 143mm 23.5mm 19mm 12.3mm 3.5mm 57A 16 94 10.2 20.5 143 20.5 23.5 Ø5 Ø3.2 CTSN433/12MF CTSN431/12MF 20.5 10.2 8 3.4 16.4 2.85 3 15.5 Ø2.75 20.5 119.4 16 8 3.2 CIRCULAR CONNECTORS Voltage (max 4.3 100 • Moulded in natural PA6, self extinguishing to UL94-V2 • Passes 960°C glow-wire test according to EN 60695-2-11 • Easily cut to size • Supplied cut to length on request • Printing available on request • approved 3.2 WIRE TO BOARD CONNECTORS S P E C I F I C AT I O N 19 095 CTSN MF CTSN434/12MF Strain relief Product overview CSR CONNECT • Clamps external conductors in lighting fixtures according to EN60598 • Natural colour PA6 • Relieves strain on cables • Prevents conductors from twisting • Protects wire coating from abrasion and friction 98 L H PA R T N O . TERMINAL STRIP LENGTH W I DT H HEIGHT CSR1 CTSN431 49.5mm 31mm 22.5mm CSR2 CTSN433 52.5mm 31mm 22.5mm CSR3 CTSN434 54.5mm 31mm 22.5mm W P 20 P K E Y F E AT U R E S Pluggable style | Easily cut to required size | V0 to GWT 960°C +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558 Vers 2
CTSN433/12/F 价格&库存
很抱歉,暂时无法提供与“CTSN433/12/F”相匹配的价格&库存,您可以联系我们找货
