CVB225/KIT
CVB225/KIT
    CAMDENBOSS
CVB225/KIT 数据手册
D I N R A I L E N C LOS U R E S Vertical DIN Rail enclosures: CVB P RODUCT OVERVIEW CVB225 CVB450 • Designed for 5mm pitch terminal blocks • Two sizes, 22.5mm or 45mm wide • Solid and perforated plates to cover unused terminal areas • Three sides accept 12-way terminal blocks each side • Complete box contains one 12-way closed, three 4-way closed and three 4-way perforated plates S P E C I F I C AT I O N CVBMSC Rating terminals 8A/250VAC Cable entry 2x2.5mm2 solid or standard Terminal protection IP20 Material PA66 UL94-V0 Recommended terminal blocks CTBP9350/8, CTBP9200/8, CTBP9350/12 and CTBP9200/12 PA R T N O . ( K I T ) DESCRIPTION SIZE CVB225/KIT Includes x1 CVB BASE, x1 CVB TOP225, x3 CVB BLIND 22.5mm x82mm x 101.75mm PLATE, x3 CVB VENT PLATE, x1 CVB BLIND PLATE LONG CVB450/KIT Includes x1 CVB BASE, x1 CVB TOP450, x3 CVB BLIND 45mm x 82mm x 101.75mm PLATE, x3 CVB VENT PLATE, x1 CVB BLIND PLATE LONG PA R T N O . ( I N D I V I D U A L P I E C E PA R T S ) DESCRIPTION CVB BASE Base CVB TOP225 225 Top CVB TOP450 450 Top CVB BLIND PLATE 4 way Solid Plate CVB VENT PLATE 4 way Vented Plate CVB BLIND PLATE LONG 12 way Solid Plate CVB TOP225 PA R T N O . DESCRIPTION SIZE CVBMSC Prototyping board See below CVB TOP450 3x CVB BLIND PLATE 3x CVB VENT PLATE 1x CVB BLIND PLATE LONG CVB BASE 3x CVB BLIND PLATE 1x CVB BLIND PLATE LONG CVB BASE K E Y F E AT U R E S PA 6 6 U L 9 4 - V 0 | D e s i g n e d f o r 5 m m p i t c h t e r m i n a l b l o c k s +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers41 Vers D I N R A I L E N C LOS U R E S 3x CVB VENT PLATE 403
CVB225/KIT 价格&库存
很抱歉,暂时无法提供与“CVB225/KIT”相匹配的价格&库存,您可以联系我们找货
CVB225/KIT
  • 1+102.83664
库存:148
