CAX2TY280
CAX2TY280
    CAMDENBOSS
CAX2TY280 数据手册
1C9A”BC IN AEBTI S N EATNSDAENNDC E LN OC SU LO RS EU S RES CamRack-QX Product overview CQX 19’’ wall mounted cabinets, designed for cabling, telecommunications, IT, industrial and home installations. • Delivered flat packed for ease of access to all installations. Also reduces associated logistic costs and offers greater protection during transit • Fast and efficient 3 minute assembly without tools • 2x 19’’ mounting profiles. Variable depth, in 20mm increments • Fast fixings 1/4 turn locks • Quick release door. Tempered safety glass • Easily removable side panels with 2x 1/4 turn locks • Easily drilled plastic blanking covers for cable entry • Template for wall mounting, included • Maximum recommended load capacity: 45kg • Finishes: Epoxy paint, RAL 7016 • Flat packed - assembled in 3 minutes! RED BLUE ORANGE WHITE B L AC K U W I DT H DEPTH HEIGHT CQX064211 CQX064212 CQX064213 CQX064214 CQX064215 6U 578mm 421mm 376mm CQX094211 CQX094212 CQX094213 CQX094214 CQX094215 9U 578mm 421mm 509mm CQX125211 CQX125212 CQX125213 CQX125214 CQX125215 12U 578mm 521mm 643mm CQX155211 CQX155212 CQX155213 CQX155214 CQX155215 15U 578mm 521mm 776mm K E Y F E AT U R E S Quick release door | Fast and efficient | Supplied flat-pack 1C9A”BC IN AEBTI S N EATNSDAENNDC E LN OC SU LO RS EU S RES Standard corner colours: 430 White Red Blue Orange Black Other corner colours available upon request: Ye l l o w Green Purple Lilac Grey ACC E SS O R I E S 19” profiles • Extra pair of 19” mount profiles • Manufactured in steel • Powder coated anthracite RAL 7016 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2.1 1 PA R T N O . U DESCRIPTION CQX010006 6U CamRack-QX 6U profiles (pair) CQX010009 9U CamRack-QX 9U profiles (pair) CQX010012 12U CamRack-QX 12U profiles (pair) CQX010015 15U CamRack-QX 15U profiles (pair) 1 9 ” C A B I N E TS A N D E N C LOS U R E S ACC E SS O R I E S Cantilever tray • • • • • • • • • Manufactured from 1.5mm steel 19’’ assembly with four anchoring points on the front sections Recommended maximum static load: 10/20 Kg Standard ventilation slots Front fastening height 2U One tray with mounting hardware Standard depths 180, 280, 350, 400mm Grey graphite expoxy paint, anthracite - RAL 7016 One tray (screws not included) PA R T N O . U DEPTH CAX2TY180 2U 180mm CAX2TY280 2U 280mm CAX2TY350 2U 350mm CAX2TY400 2U 400mm PA R T N O . U DEPTH CAXCTT280 2U 280mm • • • • • • • • • • Ideal for holding keyboards Manufactured from 1.5mm steel 19’’assembly with four anchoring points on the front sections Recommended maximum static load- 10kg Standard ventilation slots Front fastening height 2U Standard depths 280mm Grey graphite expoxy paint, anthracite - RAL 7016 Telescopic guide rails nickel plated One tray, one pair telescopic guides, one front handle Front guides mounting • 19” support guides, used as additional support for 19” equipment • Attached to rack by two anchoring points with M6 bolts • Manufactured from 2mm zintec • Zintec plated coating • One pair of guides and assembly hardware Attachment set • M6x15mm screw, PA washer, M6 caged nut 19” silver front panel • Manufactured from 3mm aluminium, clear anodised • Vented and solid profiles 19” panel anthracite • Manufactured from steel • Powder coated (RAL 7016) • Vented and solid panels PA R T N O . DESCRIPTION CAXFMG001 Front guide mounting PA R T N O . DESCRIPTION CAX000001 Attachment set (pack of 4) S TA N DA R D F R O N T VENTED FRONT U HEIGHT (MM) CAX19SPS1 CAX19VPS1 1U 43.6mm CAX19SPS2 CAX19VPS2 2U 88.1mm CAX19SPS3 CAX19VPS3 3U 132.5mm CAX19SPS4 CAX19VPS4 4U 177.0mm CAX19SPS5 CAX19VPS5 5U 221.5mm CAX19SPS6 CAX19VPS6 6U 265.9mm CAX19SPS9 CAX19VPS9 9U 399.2mm S TA N DA R D F R O N T VENTED FRONT U HEIGHT (MM) CAX19SPA1 CAX19VPA1 1U 43.6mm CAX19SPA2 CAX19VPA2 2U 88.1mm CAX19SPA3 CAX19VPA3 3U 132.5mm CAX19SPA4 CAX19VPA4 4U 177.0mm CAX19SPA5 CAX19VPA5 5U 221.5mm CAX19SPA6 CAX19VPA6 6U 265.9mm CAX19SPA9 CAX19VPA9 9U 399.2mm +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 1C9A”BC IN AEBTI S N EATNSDAENNDC E LN OC SU LO RS EU S RES Cantilever telescopic tray 431
CAX2TY280 价格&库存
很抱歉,暂时无法提供与“CAX2TY280”相匹配的价格&库存,您可以联系我们找货
CAX2TY280
  • 1+541.18629
库存:140
