CCTTPP
CCTTPP
    CAMDENBOSS
CCTTPP 数据手册
control products Contact Block Mounting Plate • NO and NC contact blocks • Screw fixed to mounting plate • Can be stacked side by side/ piggybacked • Mounting plate for contact blocks • Holds 1 or 2 NO or NC contact blocks • Metal plate must be used with metal switches Description Red NC Green NO Type No. CCTTC1R CCTTC0G Type No. CCTTP CCTTPP PCb terminal blocks Interconnection fuses & Fuseholders Description Metal Mounting plate Plastic Mounting Plate LEDs & Indicators Contact Block with Mounting Plate Miniature switches • Control blocks and mountings plates as above supplied as one assembly • Plastic plate must be used with plastic switches limit & Safety switches Description Green NO contact + metal base Red NC contact + metal base Green NO contact + plastic base Red NC contact + plastic base Type No. CC10B CC01B CC10B/P CC01B/P control products Interface modules & supports Dust Cap relay bases • Clear Silicon protection cap for push buttons • Other colours to order Type No. CCTTRDCCL enclosures Description Clear dust cap Keys for E-Stop Key Release Type No. CCTTKRD CCTTKBK batteries Sleeve Red Black transformers Button Surrounds • Yellow engraved black emergency stop • Black name plate with recessed label area Type No. CCTTBES CCTTBNP Description 60mm diameter e-stop Name plate blank +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 149 Ver 1.0 Iss 1 ELEC T RON IC S & ENC LOSURES
CCTTPP 价格&库存
很抱歉,暂时无法提供与“CCTTPP”相匹配的价格&库存,您可以联系我们找货
