CCU4C/CK
CCU4C/CK
    CAMDENBOSS
    CAMDENBOSS - CCU4C/CK - CLAMP SET, IP68, 104 PLUG, 5.7-6.7MM
CCU4C/CK 数据手册
CIRCULAR CONNECTORS PLUGS SOCKETS 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS Push-pull connectors cable mounted plug CCA4 series C C A 4 P 1 /A 1 6 16 pole CCA4P1/A16 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, marine, security, industrial and agricultural applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Tested to IEC 60512-3-5a S P E C I F I C AT I O N PA R T N O . DESCRIPTION POLES SERIES CCA4P1/A16 Cable mounted plug 16 CCA series 158 INTERFACE MODULES AND RELAY BASES ~50 Ø8.7 15 ~38 13 Shell style/model Cable mounted straight plug, male contact Codes Code 1 Contact type Solder type Contact diameter 0.7mm Max. stranded conductor AWG 21-22 Max diameter 0.79mm Vtest (contact-shell) 1000V(AC) 1600V(DC) Vtest (contact-contact) 1500V(AC) 2200V(DC) Rated current 4.0A Rated voltage ≤200V Mechanical operation 5000 mating cycles Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) 13 This product should be used with the following cable clamps: PA R T N O . WIRE RANGE CCU4C/CK 5.7 - 6.7mm CCU4C/CN 6.7 - 7.7mm CCU4C/CQ 7.7 - 8.7mm 1 Non IP68 cable clamps also available ACC E SS O R I E S Metal cap for plugs PA R T N O . DESCRIPTION CCA42 Camcirc metal cap for plug A4 A S S O C I AT E D P R O D U C T S CONNECT C C M 4 S 1 / 1 6 116 - C C M s e r i e s A 4 s i z e s o c k e t page 130 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CCU4C/CK 价格&库存
很抱歉,暂时无法提供与“CCU4C/CK”相匹配的价格&库存,您可以联系我们找货
