CE10.00.EI
CE10.00.EI
    CAMDENBOSS
CE10.00.EI 数据手册
LIMIT SWITCHES 178 MICROSWITCHES DIECAST ACCESSORIES 30mm wide limit switches 182 TACTILE SWITCHES Product overview FOOT SWITCHES 203 PIEZO SWITCHES AND KEYPADS IP65 METAL HEAD PLASTIC CASING CASING CE10.00.AM CE10.00.AP CE10.00.AI CE10.00.BM CE10.00.BP CE10.00.BI CE10.00.GM CE10.00.GP CE10.00.HM 50g Impulse withstand voltage 6kV Working temperture -25°C to +70°C Switching frequency 3600 cycles/h Load factor 0.5 Short circuit protection 10A gG fuse MAX ACTUATION ACTUATION / NC SPEED OPERATION Plain Plunger 0.5ms -1 15N/30N Roller Plunger 0.3ms-1 12N/30N CE10.00.GI Adjustable Rod Lever 1.5ms-1 0.10Nm/0.32Nm CE10.00.HP CE10.00.HI Adjustable Rod Lever 1.3ms-1 0.10Nm/0.32Nm CE10.00.EM CE10.00.EP CE10.00.EI Roller Lever Nylon 1.5ms-1 0.10Nm/0.32Nm CE10.00.EM/50 CE10.00.EP/50 CE10.00.EI/50 Rubber Roller Lever 1.5ms-1 0.10Nm/0.32Nm CE10.00.FM CE10.00.FP CE10.00.FI Adjustable Roller Lever 1.5ms-1 0.10Nm/0.32Nm CE10.00.FM/50 CE10.00.FP/50 CE10.00.FI/50 Adjustable Rubber Roller Lever 1.5ms-1 0.10Nm/0.32Nm CE10.00.IM CE10.00.IP CE10.00.II Nylon Roller Lever 1.5ms-1 0.10Nm/0.32Nm CE10.00.FRM/50 CE10.00.FRP/50 CE10.00.FRI/50 Adjustable Lever Adjustable Roller 1.5ms 0.10Nm/- CE10.00.HLTM CE10.00.HLTP CE10.00.HLTI Nylon Actuator, Stainless Steel Spring 1.5ms-1 0.10Nm/0.32Nm CE10.00.KM CE10.00.KP CE10.00.KI Nylon One Way Roller, Steel Plunger 1.5ms-1 0.10Nm/0.32Nm CE10.00.KMN CE10.00.KPN CE10.00.KIN Nylon One Way Roller, Nylon Plunger 1.5ms-1 0.10Nm/0.32Nm PLUNGER TYPE -1 Adjustable rod lever 8 39.5 Adjustable rod lever 8 Maxi 257.5 17.5 17.5 72.5...131 17.5 17.5 12.5 30Y 42 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 9 Nylon one way roller 39 9 124 Ø7 92 17.5 36 127.5...186 72.5...131 17.5 116 61 SWITCH 194 59...78 51...70 Ø50 42 Nylon, Stainless steel spring lever 8 39.5 Adjustable lever adjustable roller 48.8 15.5 5.5 Ø18 36 Ø12.5 Nylon roller lever Ø50 5.5 179 108 17.5 124 17.5 53 36 52 44.5 32.5 9 45.5...117.5 15 5.5 Adjustable rubber roller lever 45.5 41 34 Ø18 51 43.5 Ø50 69 Ø18 Adjustable roller lever 100.5...172.5 AM 1 F12 Rubber roller lever 45 40 44 44 86 75 Roller lever nylon 3.5 Ø6 195 Ø11 Ø6 Maxi 257.5 12.5 17.5 30Y 25 20 20 12.5 Ø8 Maxi 257.5 Pole plunger 31 Plain plunger 39.5 195 LIMIT SWITCHES IP65 PLASTIC CASING 500V Shock withstand Maxi 257.5 193 IP66 METAL Rating 127.5...186 191 30mm width Double insulated plastic Plastic option to IP65 Metal ption to IP66 Snap action contacts US , C approved 20 22MM CONTROL SWITCHES • • • • • • 31 186 S P E C I F I C AT I O N CE 10 44 5
CE10.00.EI 价格&库存
很抱歉,暂时无法提供与“CE10.00.EI”相匹配的价格&库存,您可以联系我们找货
