CE20.00.D000
CE20.00.D000
    CAMDENBOSS
    CAMDENBOSS - CE20.00.D000 - Limit Switch, 0° Head, 50mm Width, Adjustable Top Plunger, SPST-NC, 4 A,...
CE20.00.D000 数据手册
Call our sales team today on 01638 716101 LIMIT SWITCHES 50mm Limit Switches for Lift Door Control Product overview PA R T N O DESCRIPTION CE20.00.D000 Two threaded cable entries for PG 13.5 cable gland - 0° head orientation CE20.00.D090 Two threaded cable entries for PG 13.5 cable gland - 90° head orientation • Position Switch — Door switch suitable for lift applications CE20.00.D180 Two threaded cable entries for PG 13.5 cable gland - 180° head orientation • IP67 protection degree CE20.00.D270 Two threaded cable entries for PG 13.5 cable gland - 270° head orientation • Positive opening door switches • Door contact limit switches suitable for lift door control • Slow action contact (1NC) positive opening — Double insulating • Actuator included - also offered separately Te c h n i c a l V i e w Static 3D View SWITCH S P E C I F I C AT I O N 02 CASING MATERIAL Reinforced thermoplastic WIDTH 50mm ELECTRICAL CONNECTIONS Two cable inlets for PG 13.5 cable gland IP DEGREE OF PROTECTION IP65 ACTUATING HEAD Adjustable actuator HEAD MATERIAL Thermoplastic head MICROSWITCH Slow ation contact (1NC) positive opening APPROVALS cULus, EAC REFERENCE DIRECTIVES LVD - 2014/35/EU - LVD - 2014/33/EU REFERENCE STANDARDS IEC 60947-5-1 / EN 60947-5-1 / EN 81-20, EN 81-50 OPERATING TEMPERATURES -25°C ... +70°C STOCK TEMPERATURES -25°C ... +70°C PROTECTION AGANIST ELECTRIC SHOCKS [CLASSE (ACCORDING TO IEC 60536)] Class II - Double Insulation RATED INSULATING VOLTAGE 400V POLLUTION DEGREE 3 CONTACT RATING ACCORDING TO UL50 415Vac 4A Pilot Duty / 24Vdc 3A Pilot Duty RATED IMPULSIVE VOLTAGE 6kv CONVENTIONAL THERMAL CURRENT IN FREE AIR 10A SHORT CIRCUIT PROTECTION 10A RATED OPERATIONAL CURRENT IE - AC-15 (50-60 HZ) [ACCORDING TO IEC60947-5-1] 400V - 4A DC-13 OPERATING CURRENTS [ACCORDING TO IEC 60947-5-1] 24V - 3A SWITCHING FREQUENCY 3600 RESISTANCE BETWEEN CONTACTS 25mΩ CONNECTING TERMINALS M3.5 screw with cable clamp (+,-) CONNECTING CABLE DIMENSIONS 0.75 ... 2.5mm2 MARKING TERMINALS According to IEC 60947-5-1 MECHANICAL DURABILITY [MILLIONS OF MANEUVERS] 1 B10D [MILLIONS OF MANEUVERS] 2 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1
CE20.00.D000 价格&库存
很抱歉,暂时无法提供与“CE20.00.D000”相匹配的价格&库存,您可以联系我们找货
