CSACTT004
CSACTT004
    CAMDENBOSS
CSACTT004 数据手册
Call our sales team today on 01638 716101 or visit www.camdenboss.com U N I V E R SA L E N C LOS U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 1100 Series Recessed Electronics Enclosure Product overview 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES The 1100 Series Recessed Electronics Enclosure is 100% recyclable and manufactured in the UK. Designed with aesthetically pleasing external bevelled edges and smooth curved ends and straight sides, the enclosure can be used for a range of user facing electronics devices and technology in industries such as industrial, medical and IoT. The UL94-V0 rated ABS enclosure is available with either a solid grey ABS lid or transparent polycarbonate lid. Both options have a recess on the top and the base to allow for membranes, keypads, overlays and digital printing. If you are looking for a high quality functional enclosure, look no further! Two recessed sides 1.2mm recess in both the lid and base for product labels and overlays Key features Modern aesthetic Bevelled edges and curved 2.5mm side walls 367 VERSATILE IOT AND SENSOR ENCLOSURES Two lid options Select from either a solid grey or transparent lid Fixing pillars Designed to take thread forming screws (included). No inserts allows for easy recycling! 370 CUSTOM SIZED ENCLOSURES Deep profile Maximises the internal volume for increased component and PCB space PCB mounting Four mounting points in the base of the enclosure H L W Enclosure dimensions P L AST I C E N C LOS U R E S EXTERNAL DIMENSIONS 298 INTERNAL DIMENSIONS WA L L THICKNESS SIZE SOLID LID T R A N S PA R E N T L I D LENGTH W I DT H HEIGHT LENGTH W I DT H HEIGHT Size 1 CSACST001 CSACTT001 90mm 50mm 35mm 85mm 45mm 2.5mm 2.5mm Size 2 CSACST002 CSACTT002 110mm 60mm 40mm 105mm 55mm 32.5mm 2.5mm Size 3 CSACST003 CSACTT003 125mm 75mm 50mm 120mm 70mm 42.5mm 2.5mm Size 4 CSACST004 CSACTT004 155mm 95mm 60mm 150mm 90mm 52.5mm 2.5mm Size 5 CSACST005 CSACTT005 190mm 115mm 75mm 185mm 150mm 67.5mm 2.5mm Size 6 CSACST006 CSACTT006 220mm 140mm 90mm 215mm 135mm 82.5mm 2.5mm PCB sizes positions SIZE MOUNTING POSITION MAX LENGTH M AX W I DT H M O U N T I N G H O L E S PA C I N G Size 1 Enclosure base 82mm 43mm 58 x 30mm Size 2 Enclosure base 101.5mm 52.5mm 75 x 40mm Size 3 Enclosure base 114.5mm 67.5mm 90 x 55mm Size 4 Enclosure base 143mm 88mm 118 x 75mm Size 5 Enclosure base 177mm 108mm 152 x 95mm Size 6 Enclosure base 205mm 132.5mm 180 x 120mm +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 2 1 FM 28614 Call our sales team today on 01638 716101 or visit www.camdenboss.com U N I V E R SA L E N C LOS U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES 292 UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES Potential industries/ applications R A N G E S P E C I F I C AT I O N STANDARD UNIT INCLUDES 1 x base, 1 x lid, 3mm x 20mm thread-forming screw x4 Enclosure UL94-V0 ABS (gloss finish) Solid lid UL94-V0 ABS (gloss finish) Transparent lid UL94-V0 polycarbonate Thread-forming screws Zinc Plated Steel COLOURS Grey RAL7047 COMPLIANCE RoHS compliant IP RATING IP54 MATERIALS OPERATING TEMPERATURE Base -5°C to 80°C Grey lid -5°C to 80°C Transparent lid TEST RESULTS SCREW TORQUE PURCHASING INFORMATION -5°C to 120°C Test Result Test report UL94 Flammability UL94-V0 TR113 EN62262 Impact test IK06 TR111 EN60529 Ingress protection IP54 N/A Lid 0.3Nm PCB 0.3Nm Country of origin Great Britain (GB) Commodity code 39231010 Enclosure type OPTIONS The image below represents the enclosure used in an industrial setting, operating as a flow pressure device with a smart control panel. Standard Weight The 1100 Series Recessed Electronics Enclosure is ideal for use as HVAC, industrial technology, IoT, IIoT, solar controllers, sensors and monitoring equipment, desktop devices, lighting control, medical, retail, domestic and much more... 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 VERSATILE IOT AND SENSOR ENCLOSURES 370 CUSTOM SIZED ENCLOSURES Size 1: 54g Size 4: 185g Size 2: 76g Size 5: 267g Size 3: 110g Size 6: 325g Universal For alternative colours and materials MOQs will apply. Accessories Customisation options Elevate your enclosure to the next level with our in-house customisation services. These include digital printing, screen printing, DIN Rail Mount Bracket machining / drilling and engraving. P L AST I C E N C LOS U R E S (CDR-Bracket) Universal Wall Mount Bracket (CBWM-10xx) +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers 1 299
CSACTT004 价格&库存
很抱歉,暂时无法提供与“CSACTT004”相匹配的价格&库存,您可以联系我们找货
CSACTT004
    • 1+164.63235
    库存:105
