PCB
TERMINAL
BLOCKS
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
5.08mm & 10.16mm Pitch Screwless Top Entry Terminal Blocks
• 2-24 pole solid block
5.08mm pitch
• 1-10 pole solid block
10.16mm pitch
• Top entry for cable
and release point
• Moulded in grey UL94-V0 Flame
retardant PA
• 0.5-1.5mm2 (30-16AWG)
solid & stranded cable
approved
SPECIFICATION
Rating
CSTBV23
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/contact
Spring
Reccommended PCB hole size
5.08mm
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
TYPE NO.
CSTBV23/2
CSTBV23/3
CSTBV23/4
CSTBV23/5
CSTBV23/6
CSTBV23/7
CSTBV23/8
CSTBV23/9
CSTBV23/10
CSTBV23/11
CSTBV23/12
CSTBV23/13
CSTBV23/14
CSTBV23/15
CSTBV23/16
CSTBV23/17
CSTBV23/18
CSTBV23/19
CSTBV23/20
CSTBV23/21
CSTBV23/22
CSTBV23/23
CSTBV23/24
POLES
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
LENGTH
10.2mm
15.2mm
20.3mm
25.4mm
30.5mm
35.6mm
40.6mm
45.7mm
50.8mm
55.9mm
61mm
66mm
71.1mm
76.2mm
81.3mm
86.4mm
91.4mm
96.5mm
101.6mm
106.7mm
111.8mm
121.9mm
131.9mm
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
10.16mm
5.08mm
16A/630V
16A/320V
UL=10A/300V
UL=10A/300V
VDE&IMQ=16A750V
VDE&IMQ=16A/450V
≥ 3kV
≥ 2.5kV
6kV
4kV
110°C
Grey UL 94 V0 flame retardant PA
Copper alloy, NI & SN
INOX Steel
ø1.1mm
很抱歉,暂时无法提供与“CSTBV23/2”相匹配的价格&库存,您可以联系我们找货
