P C B T E R M I N A L B LO C KS
S TA N D A R D
PLUGGABLES
SCREWLESS
ECONOMY RANGE
5.08mm pitch pluggable rising
clamp terminal blocks
Product overview
E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS
19
2-12 pole solid block
Up to 24 poles available
Pluggable male-female connectors
Professional rising clamp terminals
Closed headers
Polarised mouldings
Moulded in green UL94-V0 flame
retardant PA66
0.33-2mm2 (22-14AWG) solid &
stranded cable
Captive screws
Guided pin alignment
approved
PA R T N O .
POLES
LENGTH
CTB9209/2
2
10.2mm
CTB9209/3
3
15.2mm
CTB9209/4
4
20.3mm
CTB9209/5
5
25.4mm
CTB9209/6
6
30.5mm
CTB9209/7
7
35.6mm
CTB9209/8
8
40.6mm
CTB9209/9
9
45.7mm
CTB9209/10
10
50.8mm
CTB9209/11
11
55.9mm
CTB9209/12
12
61mm
PA R T N O .
POLES
LENGTH
CTB922VJ/2S
2
10.2mm
CTB922VJ/3S
3
15.2mm
CTB922VJ/4S
4
20.3mm
CTB922VJ/5S
5
25.4mm
CTB922VJ/6S
6
30.5mm
CTB922VJ/7S
7
35.6mm
CTB922VJ/8S
8
40.6mm
CTB922VJ/9S
9
45.7mm
CTB922VJ/10S
10
50.8mm
CTB922VJ/11S
11
55.9mm
CTB922VJ/12S
12
61mm
PA R T N O .
POLES
LENGTH
CTB922VJ/2R
2
10.2mm
CTB922VJ/3R
3
15.2mm
CTB922VJ/4R
4
20.3mm
CTB922VJ/5R
5
25.4mm
CTB922VJ/6R
6
30.5mm
CTB922VJ/7R
7
35.6mm
CTB922VJ/8R
8
40.6mm
CTB922VJ/9R
9
45.7mm
CTB922VJ/10R
10
50.8mm
CTB922VJ/11R
11
55.9mm
CTB922VJ/12R
12
61mm
S P E C I F I C AT I O N
Rating
15A 300V
Insulation resistance
1000M Ω/1000V
Withstand voltage
AC1000V/1min
Contact resistance
20m Ω
Working temperature
-40°C to +105°C
Mouldings
UL94-V0 flame retardant PA66
Wire protector
Tin plated, phosphor bronze
Screw/torque
M2.5 steel, tin plated 0.4Nm
Recommended PCB hole size
ø1.7mm
CTB9209
CTB922VJ S
CTB922VJ R
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
EMS 613558
SCREWLESS
PLUGGABLES
S TA N D A R D
ECONOMY RANGE
CTB9309/3
3
16.4mm
CTB9309/4
4
21.5mm
CTB9309/5
5
26.6mm
CTB9309/6
6
31.7mm
CTB9309/7
7
36.78mm
CTB9309/8
8
41.8mm
CTB9309/9
9
46.9mm
CTB9309/10
10
52mm
CTB9309/11
11
57.1mm
CTB9309/12
12
62.3mm
PA R T N O .
POLES
LENGTH
TB9359/2
2
11.4mm
CTB9359/3
3
16.4mm
CTB9359/4
4
21.5mm
CTB9359/5
5
26.6mm
CTB9359/6
6
31.7mm
CTB9359/7
7
36.78mm
CTB9359/8
8
41.8mm
CTB9359/9
9
46.9mm
CTB9359/10
10
52mm
CTB9359/11
11
57.1mm
CTB9359/12
12
62.3mm
PA R T N O .
POLES
LENGTH
CTB9309/2AO
2
11.4mm
CTB9309/3AO
3
16.4mm
CTB9309/4AO
4
21.5mm
CTB9309/5AO
5
26.6mm
CTB9309/6AO
6
31.7mm
CTB9309/7AO
7
36.78mm
CTB9309/8AO
8
41.8mm
CTB9309/9AO
9
46.9mm
CTB9309/10AO
10
52mm
CTB9309/11AO
11
57.1mm
CTB9309/12AO
12
62.3mm
CTB9309
12.2
CTB9359
12.1
CTB9309 AO
11.4mm
3.7
LENGTH
2
3.75
POLES
CTB9309/2
7.82
PA R T N O .
8.23
FM 28614
EMS 613558
Vers 1
很抱歉,暂时无法提供与“CTB9309/4”相匹配的价格&库存,您可以联系我们找货
