P C B T E R M I N A L B LO C KS
S TA N D A R D
PLUGGABLES
SCREWLESS
002
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
3.5mm pitch pluggable rising clamp
terminal blocks
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
S P E C I F I C AT I O N
• 2-12 pole solid block professional rising clamp terminals
• Moulded in green UL94-V0 flame retardant PA66
• Cable acceptance - 0.32 to 1.3mm2 (28-16AWG) solid
and stranded cable
• Polarised mouldings
• Pluggable male and female connectors
• Closed headers
• Horizontal and vertical female plug styles
• Anti solder wicking
• Captive screws
• Guided pin alignment
• C
approved
US ,
Rating
UL=8A/300V, VDE=10A/250V
Insulation resistance
500M Ω/500V
Withstand voltage
AC2000V/1min
Contact resistance
20mΩ (max)
Working temperature
-40°C to +105°C
Moulding
Pin/terminal
Tin plated brass
Rising clamp
Brass, nickel plated
Screw/torque
M2 steel, zinc plated 0.2Nm
Recommended PCB hole size
ø1.4mm
Female connector
PA R T N O .
POLES
LENGTH
CTBP92HD/2
2
7.8mm
CTBP92HD/3
3
11.3mm
CTBP92HD/4
4
14.8mm
CTBP92HD/5
5
18.3mm
CTBP92HD/6
6
21.8mm
CTBP92HD/7
7
25.3mm
CTBP92HD/8
8
28.8mm
CTBP92HD/9
9
32.3mm
CTBP92HD/10
10
35.8mm
CTBP92HD/11
11
39.3mm
CTBP92HD/12
12
42.8mm
CTBP92HD
16.2
3.5
6.7
2.2
INTERFACE
MODULES AND
RELAY BASES
11.2
158
Female vertical connector (standard)
LENGTH
2
7.8mm
CTBP92VD/3S
3
11.3mm
CTBP92VD/4S
4
14.8mm
CTBP92VD/5S
5
18.3mm
CTBP92VD/6S
6
21.8mm
CTBP92VD/7S
7
25.3mm
CTBP92VD/8S
8
28.8mm
CTBP92VD/9S
9
32.3mm
CTBP92VD/10S
10
35.8mm
CTBP92VD/11S
11
39.3mm
CTBP92VD/12S
12
42.8mm
CTBP92VD S
10.5
19.2
POLES
CTBP92VD/2S
6.6
PA R T N O .
3.5
58
POLES
LENGTH
CTBP92VD/2R
2
7.8mm
CTBP92VD/3R
3
11.3mm
CTBP92VD/4R
4
14.8mm
CTBP92VD/5R
5
18.3mm
CTBP92VD/6R
6
21.8mm
CTBP92VD/7R
7
25.3mm
CTBP92VD/8R
8
28.8mm
CTBP92VD/9R
9
32.3mm
CTBP92VD/10R
10
35.8mm
CTBP92VD/11R
11
39.3mm
CTBP92VD/12R
12
42.8mm
CTBP92VD R
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
10.5
19.2
PA R T N O .
6.6
CONNECT
Female vertical connector (reversed)
3.5
SCREWLESS
PLUGGABLES
S TA N D A R D
002
PCB TERMINAL
BLOCKS
PCB mounting male horizontal connector (closed ended)
8.4mm
CTBP93HD/3
3
11.9mm
CTBP93HD/4
4
15.4mm
CTBP93HD/5
5
18.9mm
CTBP93HD/6
6
22.4mm
CTBP93HD/7
7
25.9mm
CTBP93HD/8
8
29.4mm
CTBP93HD/9
9
32.9mm
CTBP93HD/10
10
36.4mm
CTBP93HD/11
11
39.9mm
CTBP93HD/12
12
43.4mm
CTBP93HD
081
TERMINAL STRIPS
3.5
095
WIRE TO BOARD
CONNECTORS
7.2
9.2
LENGTH
2
0.8
POLES
CTBP93HD/2
1.2
PA R T N O .
100
3.4
CIRCULAR
CONNECTORS
PCB mounting male vertical connector (closed ended)
LENGTH
CTBP93VD/2
2
8.4mm
CTBP93VD/3
3
11.9mm
CTBP93VD/4
4
15.4mm
CTBP93VD/5
5
18.9mm
CTBP93VD/6
6
22.4mm
CTBP93VD/7
7
25.9mm
CTBP93VD/8
8
29.4mm
CTBP93VD/9
9
32.9mm
CTBP93VD/10
10
36.4mm
CTBP93VD/11
11
39.9mm
CTBP93VD/12
12
43.4mm
151
IP68 CONNECTORS
CTBP93VD
158
INTERFACE
MODULES AND
RELAY BASES
7.2
9.2
POLES
0.8
3
3.4
PA R T N O .
3.5
A S S O C I AT E D P R O D U C T S
C T B 92 H D, C T B 92 V D S a n d C T B P 92 V D R c a n b e re p l a ce d w i t h a s c rew l e ss t y p e te r m i n a l
block for a reduced assembly time.
page 77
CONNECT
CSTBP92HD
Vers 1
59
很抱歉,暂时无法提供与“CTBP92VD/3S”相匹配的价格&库存,您可以联系我们找货
