SCREWLESS
PLUGGABLES
S TA N D A R D
P C B T E R M I N A L B LO C KS
002
PCB TERMINAL
BLOCKS
5.08mm pitch pluggable rising
clamp terminal blocks
Product overview
081
TERMINAL STRIPS
S P E C I F I C AT I O N
2-24 pole solid block
Professional rising clamp terminals
Moulded in green UL94-V0 flame retardant PA66
Cable acceptance - 0.32 to 1.6mm2 (28-14AWG) solid
and stranded cable
Pluggable male and female connectors
Open and closed headers
Horizontal and vertical female plug styles
Polarised mouldings
Anti solder wicking
Captive screws and guided pin alignment
approved
US ,
C
Rating
UL=15A/300V, VDE=20A/450V
Insulation resistance
500M Ω/500V
Withstand voltage
AC2000V/1min
Contact resistance
20mΩ (max)
Working temperature
-40°C to +105°C
Mouldings
Pin/terminal
Tin plated brass
Rising clamp
Brass, nickel plated
Screw/torque
M3 steel, zinc plated 0.5Nm
Recommended PCB hole size
ø1.7mm
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
Female connector
10.2mm
CTBP9208/3
3
15.2mm
CTBP9208/4
4
20.3mm
CTBP9208/5
5
25.4mm
CTBP9208/6
6
30.5mm
CTBP9208/7
7
35.6mm
CTBP9208/8
8
40.6mm
CTBP9208/9
9
45.7mm
CTBP9208/10
10
50.8mm
CTBP9208/11
11
55.9mm
CTBP9208/12
12
61mm
CTBP9208
158
18.1
LENGTH
2
8.3
POLES
CTBP9208/2
INTERFACE
MODULES AND
RELAY BASES
5.08
15.05
PA R T N O .
Female vertical connector (standard)
10.2mm
CTBP92VJ/3S
3
15.2mm
CTBP92VJ/4S
4
20.3mm
CTBP92VJ/5S
5
25.4mm
CTBP92VJ/6S
6
30.5mm
CTBP92VJ/7S
7
35.6mm
CTBP92VJ/8S
8
40.6mm
CTBP92VJ/9S
9
45.7mm
CTBP92VJ/10S
10
50.8mm
CTBP92VJ/11S
11
55.9mm
CTBP92VJ/12S
12
61mm
CTBP92VJ S
5.08
26
LENGTH
2
8.3
POLES
CTBP92VJ/2S
12.6
PA R T N O .
Female vertical connector (reversed)
CTBP92VJ/3R
3
15.2mm
CTBP92VJ/4R
4
20.3mm
CTBP92VJ/5R
5
25.4mm
CTBP92VJ/6R
6
30.5mm
CTBP92VJ/7R
7
35.6mm
CTBP92VJ/8R
8
40.6mm
CTBP92VJ/9R
9
45.7mm
CTBP92VJ/10R
10
50.8mm
CTBP92VJ/11R
11
55.9mm
CTBP92VJ/12R
12
61mm
CTBP92VJ R
5.08
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
CONNECT
10.2mm
26
LENGTH
2
8.3
POLES
CTBP92VJ/2R
12.6
PA R T N O .
65
S TA N D A R D
PLUGGABLES
SCREWLESS
002
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
158
LENGTH
2
11.6mm
CTBP9308/3
3
16.6mm
CTBP9308/4
4
21.7mm
CTBP9308/5
5
26.8mm
CTBP9308/6
6
31.9mm
CTBP9308/7
7
37.0mm
CTBP9308/8
8
42.0mm
CTBP9308/9
9
47.1mm
CTBP9308/10
10
52.2mm
CTBP9308/11
11
57.3mm
CTBP9308/12
12
62.4mm
CTBP9308
7.8
3.9
5.08
1
PCB mounting male horizontal connector (closed ended)
PA R T N O .
POLES
LENGTH
CTBP9358/2
2
11.6mm
CTBP9358/3
3
16.6mm
CTBP9358/4
4
21.7mm
CTBP9358/5
5
26.8mm
CTBP9358/6
6
31.9mm
CTBP9358/7
7
37.0mm
CTBP9358/8
8
42.0mm
CTBP9358/9
9
47.1mm
CTBP9358/10
10
52.2mm
CTBP9358/11
11
57.3mm
CTBP9358/12
12
62.4mm
CTBP9358
5.08
4
7.8
1
3
12
2
INTERFACE
MODULES AND
RELAY BASES
POLES
CTBP9308/2
8.5
095
PA R T N O .
8.5
TERMINAL STRIPS
4
081
PCB mounting male vertical connector (closed ended)
12
PCB TERMINAL
BLOCKS
PCB mounting male vertical connector (open ended)
CTBP9308/3AO
3
15.2mm
CTBP9308/4AO
4
20.3mm
CTBP9308/5AO
5
25.4mm
CTBP9308/6AO
6
30.5mm
CTBP9308/7AO
7
35.6mm
CTBP9308/8AO
8
40.6mm
CTBP9308/9AO
9
45.7mm
CTBP9308/10AO
10
50.8mm
CTBP9308/11AO
11
55.9mm
CTBP9308/12AO
12
61mm
CTBP9308 AO
8.5
10.2mm
7.8
3.9
5.08
1
1
4
LENGTH
2
2
POLES
CTBP9308/2AO
12
PA R T N O .
66
LENGTH
2
10.2mm
CTBP9358/3AO
3
15.2mm
CTBP9358/4AO
4
20.3mm
CTBP9358/5AO
5
25.4mm
CTBP9358/6AO
6
30.5mm
CTBP9358/7AO
7
35.6mm
CTBP9358/8AO
8
40.6mm
CTBP9358/9AO
9
45.7mm
CTBP9358/10AO
10
50.8mm
CTBP9358/11AO
11
55.9mm
CTBP9358/12AO
12
61mm
CTBP9358 AO
Vers 1
8.5
POLES
CTBP9358/2AO
5.08
7.8
1
4
12
PA R T N O .
2
CONNECT
PCB mounting male horizontal connector (open ended)
很抱歉,暂时无法提供与“CTBP9358/10AO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+5.74266
- 50+5.49350
- 100+5.14941
- 250+4.78160
- 500+4.60362
- 1500+4.50870
