CCE1S1/07
CCE1S1/07
    CAMDENBOSS
    CAMDENBOSS - CCE1S1/07 - Circular Connector, IP68, CamCirc CCE Series, Panel Mount Receptacle, 7 Con...
CCE1S1/07 数据手册
CIRCULAR CONNECTORS PLUGS SOCKETS ACC E SS O R I E S 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS Push-pull connectors female fixed socket CCE series CCE1S1/07 7 pole CCE1S1/07 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, marine, security, industrial and agricultural applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Tested to IEC 60512-3-5a 158 S P E C I F I C AT I O N PA R T N O . DESCRIPTION CCE1S1/07 Female fixed socket INTERFACE MODULES AND RELAY BASES DBEU type fixed socket, female contact Codes Code 1 Contact type Solder type Contact diameter 0.5mm Max. stranded conductor AWG 21-22 Max diameter 0.43mm Vtest (contact-shell) 800V(AC) 1300V(DC) Vtest (contact-contact) 1000V(AC) 1800V(DC) Rated current 2.0A Rated voltage ≤160V POLES SERIES Mechanical operation 5000 mating cycles 07 CCE series Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) ~ 20 Ø14 M9*0.5 10.2 11 11 0-3.5 Shell style/model 2.5 K E Y F E AT U R E S Key coded | Panel mounting socket | Raised plug for location in low light conditions ACC E SS O R I E S Metal and rubber caps for sockets PA R T N O . DESCRIPTION CCT11 Camcirc metal cap for sockets A1 PA R T N O . DESCRIPTION CCT12 Camcirc rubber cap for sockets A1 CONNECT A S S O C I AT E D P R O D U C T S 142 C C A 1 P 1 /A 0 7 - C C A S e r i e s A 1 s i z e p l u g page 105 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614
CCE1S1/07 价格&库存
很抱歉,暂时无法提供与“CCE1S1/07”相匹配的价格&库存,您可以联系我们找货
