CCT1S1/03
CCT1S1/03
    CAMDENBOSS
    CAMDENBOSS - CCT1S1/03 - Circular Connector, IP68, CamCirc CCT Series, Cable Mount Receptacle, 3 Con...
CCT1S1/03 数据手册
CIRCULAR CONNECTORS PLUGS SOCKETS ACC E SS O R I E S 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES Push-pull connectors female cable mount CCT series CCT1S1/03 3 pole CCT1S1/03 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, security and industrial applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Cable mounting • Tested to IEC 60512-3-5a • Cable clamp required for use with this series S P E C I F I C AT I O N PA R T N O . DESCRIPTION POLES SERIES CCT1S1/03 Female cable mount 3 CCT series Ø10 Ø5.1 ~35 7 1 7 Shell style/model Free cable mount socket connector, female contact Codes Code 1 Contact type Solder type Contact diameter 0.9mm Max. stranded conductor AWG 21-22 Max diameter 0.79mm Vtest (contact-shell) 1300V(AC) 1800V(DC) Vtest (contact-contact) 1300V(AC) 1600V(DC) Rated current 8.2A Rated voltage ≤250V Mechanical operation 5000 mating cycles Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) K E Y F E AT U R E S Key coded | Cable mounting socket | This product should be used with the following cable clamps: Cable clamps required PA R T N O . WIRE RANGE CCV1C/CC 2.6 - 3.1mm CCV1C/CD 3.1-3.6mm CCV1C/CE 3.6-4.1mm CCV1C/CF 4.1-4.3mm Non IP68 cable clamps also available ACC E SS O R I E S CONNECT Metal and rubber caps for sockets 146 PA R T N O . DESCRIPTION CCT11 Camcirc metal cap for sockets A1 PA R T N O . DESCRIPTION CCT12 Camcirc rubber cap for sockets A1 A S S O C I AT E D P R O D U C T S C C A 1 P 1 /A 0 3 - C C A S e r i e s A 1 s i z e p l u g page 102 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614
CCT1S1/03 价格&库存
很抱歉,暂时无法提供与“CCT1S1/03”相匹配的价格&库存,您可以联系我们找货
