CCV2C/CE
CCV2C/CE
    CAMDENBOSS
    CAMDENBOSS - CCV2C/CE - CLAMP SET, IP68, 103, 3.7-4.2MM
CCV2C/CE 数据手册
SOCKETS PLUGS CIRCULAR CONNECTORS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES Push-pull connectors cable mounted plug CCA2 series C C A 2 P 1 /A 0 3 3 pole CCA2P1/A03 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, marine, security, industrial and agricultural applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Tested to IEC 60512-3-5a S P E C I F I C AT I O N PA R T N O . DESCRIPTION POLES SERIES CCA2P1/A03 Cable mounted plug 3 CCA series ~46 Ø6.7 12 ~35 10 081 TERMINAL STRIPS Shell style/model Cable mounted straight plug, male contact Codes Code 1 Contact type Solder type Contact diameter 1.18mm Max. stranded conductor AWG 17-18 Max diameter 0.43mm Vtest (contact-shell) 1200V(AC) 1800V(DC) Vtest (contact-contact) 1500V(AC) 2000V(DC) Rated current 12A Rated voltage ≤250V Mechanical operation 5000 mating cycles Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) 10 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES This product should be used with the following cable clamps: PA R T N O . WIRE RANGE CCV2C/CE 3.7 - 4.2mm CCV2C/CG 4.2 - 4.7mm CCV2C/CH 4.7 - 5.2mm CCV2C/CI 5.2 - 5.7mm CCV2C/CJ 5.7 - 6.2mm 1 Non IP68 cable clamps also available ACC E SS O R I E S Metal cap for plugs PA R T N O . DESCRIPTION CCA22 Camcirc metal cap for plug A2 C C B 2 S 1 / 0 3 - C C B s e r i e s A 2 s i z e s o c k e t CONNECT A S S O C I AT E D P R O D U C T S page 133 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 1 107
CCV2C/CE 价格&库存
很抱歉,暂时无法提供与“CCV2C/CE”相匹配的价格&库存,您可以联系我们找货
