CDIB/6/D2
CDIB/6/D2
    CAMDENBOSS
    Light Gray Polycarbonate DIN Rail Instrument Enclosure
CDIB/6/D2 数据手册
D I N R A I L E N C LOS U R E S High and low profile DIN Rail enclosures P r o d u c t overview CDIB/3 • Designed for 35mm DIN Rail mounting • DIN clips can also be used for surface mounting the housing • Multiple snap-in PCB positions available (horizontal and vertical) • x2 pillars in the base for screw fixing PCB • Snap-fit top covers and terminal guards • Open top and solid top versions available • Low and high profile variants • Enclosure base gives isolation from DIN Rail • Customisation options include cutouts, holes and vents • Surfaces, covers, terminal guards easily customised and printed • Moulded in UL94-V0 polycarbonate CDIB/6 S P E C I F I C AT I O N Material Base and body - UL94-V0, polycarbonate clips - POM Standard colours RAL 7035 Standard unit includes Body, base and clips Accessories Terminal guards and covers (see CNMB) PCB screw size No.6 x 1/4” self tapping screw PA R T N O . DESCRIPTION LENGTH W I DT H HEIGHT CDIB/3/L2 CDIB, size 3, low profile, open top, open sides 90mm 53mm 31.9mm CDIB/3/D2 CDIB, size 3, high profile, open top, open sides 90mm 53mm 114mm CDIB/3ST/L2 CDIB, size 3, low profile, solid top, open sides 90mm 53mm 31.9mm CDIB/3ST/D2 CDIB, size 3, high profile, solid top, open sides 90mm 53mm 114mm CDIB/6/L2 CDIB, size 6, low profile, open top, open sides 90mm 106.2mm 31.9mm CDIB/6/D2 CDIB, size 6, high profile, open top, open sides 90mm 106.2mm 114mm CDIB/6ST/L2 CDIB, size 6, low profile, solid top, open sides 90mm 106.2mm 31.9mm CDIB/6ST/D2 CDIB, size 6, high profile, solid top, open sides 90mm 106.2mm 114mm KITS • Each kit contains one grey panel cover and a selection of solid and perforated terminal guards COMPONENT PROFILE BASE D I N R A I L E N C LOS U R E S KIT PART NO. 398 COV E R TERMINAL GUARDS /PG /TG508P /TGS CDIB/3/L2/KIT Low 1 1 2 1 CDIB/3/D2/KIT High 1 1 2 1 CDIB/3ST/L2/KIT Low 1 0 2 1 CDIB/3ST/D2/KIT High 1 0 2 1 CDIB/6/L2/KIT Low 1 1 4 2 CDIB/6/D2/KIT High 1 1 4 2 CDIB/6ST/L2/KIT Low 1 0 4 2 CDIB/6ST/D2/KIT High 1 0 4 2 CDIB/3/D2 CDIB/6/L2 CDIB/3/L2 31.9mm 90mm 53mm CDIB/6/D2 114mm 114mm 31.9mm 90mm 106.2mm 90mm 53mm 90mm 106.2mm +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 1 Vers 3 FM 28614
CDIB/6/D2 价格&库存
很抱歉,暂时无法提供与“CDIB/6/D2”相匹配的价格&库存,您可以联系我们找货
CDIB/6/D2
  • 1+33.585101+4.35610
库存:3
