CMEB/1PC/E/KIT
CMEB/1PC/E/KIT
    CAMDENBOSS
    CAMDENBOSS - CMEB/1PC/E/KIT - Plastic Enclosure, Open Clear Top Extn., DIN Rail, Polycarbonate, 61.3...
CMEB/1PC/E/KIT 数据手册
U N I V E R SA L E N C LOS U R E S Call our sales team today on 01638 716101 CMEB Extendable DIN Rail Terminal Enclosure Product Overview The UK manufactured CMEB Extendable DIN Rail Terminal Enclosure features two removable side panels to offering accessible internal wiring. Unique extension pieces can be used to connect multiple bodies together, providing more poles and wiring options. Internal solder tags offer an effective way of connecting to PCBs or flying wires. Accommodates full size internal PCBs, with the extended version supporting horizontal or vertical PCB’s or seperators between high and low power sides. C M E B / 1 S T/ K I T Key Features CMEB/1PC/KIT CMEB/1PG/KIT Modular Design Options Clip Together Design Open Top body capable of Snap fitted parts remove the interchangeable lids, whilst Solid need for screws, streamlining the top creates a pre enclosed housing. assembly process. Adjoining Solder Tags Pre-fitted Terminals Integrated solder tag terminals Eight 7mm saddle washer terminals, simplify the assembly of your secured by M3 screws. Compliant to internal electrical componentry. EN60999-1 terminal standards. Additional PCB positions Extendable Enclosure Extended vertical and horizontal Specially designed Extension arms positions can seperate low/high allow you to assemble an enclosure voltage and input/output wires. to your width requirements. Two Removable Side Panels Dual Mounting Options Side panels clip on and clip off for Fits on a 35mm top hat DIN Rail improved access to the internal space of the enclosure. or can be mounted directly onto a CMEB/1PC/E/KIT surface. P L AST I C E N C LOS U R E S PA R T N U M B E R S ( K I T S ) 01 B O DY T Y P E PA R T N U M B E R KIT INCLUDES SOLID TOP CMEB/1ST/KIT 1x Solid top body, 2x End panels, 2x Terminal screw covers, 1x black clip, 1x white clip OPEN TOP CLEAR CMEB/1PC/KIT 1x Open top body, 2x End panels, 2x Terminal screw covers, 1x Clear top, 1x black clip, 1x white clip OPEN TOP GREY CMEB/1PG/KIT 1x Open top body, 2x End panels, 2x Terminal screw covers, 1x Grey top, 1x black clip, 1x white clip SOLID TOP EXTENSION* CMEB/1ST/E/KIT 1x Solid top body, 2x Extension arms, 2x Terminal screw covers, 1x white clip OPEN TOP CLEAR EXTENSION* CMEB/1PC/E/KIT 1x Open top body, 2x Extension arms, 2x Terminal screw covers, 1x Clear top, 1x white clip OPEN TOP GREY EXTENSION* CMEB/1PG/E/KIT 1x Open top body, 2x Extension arms, 2x Terminal screw covers, 1x Grey top, 1x white clip *Extension kits to be ordered alongside at least one standard housing e.g. For a 3 way housing please order 2 extension kits and 1 standard housing. White clip required for surface mounting. Not essential for DIN Rail mounting. Potential industries / applications Din Rail Switch Enclosures, DIN Rail Input and Output devices, DIN Rail Smart Building device, DIN Rail Power meter, DIN Rail Building control, DIN Rail stairway switch, DIN Rail Home Automation Universal Transmitters, DIN Rail Voltage Monitoring Relay, DIN Rail Relay Timer Light Switch, DIN Rail Current Monitoring Relay, Isolated Universal Temperature DIN rail Transmitter, DIN Rail MeterBus level converters, DIN Rail Solid State Relay, DIN Rail Voltage Monitoring Relay, DIN Rail Solid State Relay Industrial IoT, Home automation, smart city device, controllers, relays, switches, Transmitters, power meters. +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 U N I V E R SA L E N C LOS U R E S Call our sales team today on 01638 716101 1 A B C CMEB Extendable DIN Rail Terminal Enclosure 3 90mm x 17.86mm x 61.3mm I N T E R N A L D I M E N S I4O N S (LXWXH) D I M E N S I O N S F O R E AC H P O S I T I O N PCB MOUNTING POSITION Enclosure - 1.09mm End Panels - 1.3mm MAX PCB DIMENSIONS (LXW) A A Planar See technical drawing B Vertical 48mm x 14.7mm* C Horizontal 60.7mm x 16.5mm* D Horizontal 84.7mm x 16.5mm* E Horizontal 83mm x 16.5mm* Single enclosure B A L C W R A N G E S P E C I F I C AT I O N Enclosure 1 Extension bracket DATE 2 NAME - Screws /- Saddle Washer BY ECR DRAWN IAN PAGANO 3 Nuts Extended enclosure UL94-V0 Polycarbonate UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS JAMES CARTER RD, MILDENHALL, SUFFOLK. IP28 7DE TEL: 01638 716101 FAX: 01638 716554 EMAIL: Sales@CamdenBoss.com WEB: www.CamdenBoss.com MATERIALS CHANGE NOTE SIGNED DATE I.P - - - - CHK'D GENERAL TOLERANCES +/- 0.2 FINISH. UL94-V0 Polycarbonate TITLE: COLOUR. UL94-V0 Polycarbonate CMEB_1 LxWxH - PROJECTION. Steel BZP SCALE. - COMPLIANCE RoHS compliant ELECTRICAL RATING 8A/250V rated (EN 62208), 0.8mm thick steel & nickel-plated terminals (EN 60999-1) CONDUCTOR SIZE 8 Poles Rigid/Solid - 2.5mm2 Rigid/Stranded - 1.5mm2 Flexible - 1.5mm2 Enclosure IP40 TEST RESULTS C IP20 Test Result Test report UL94 Flammability V0 E353371 PASS 56187* 850°C 56187* PASS 56187* Resistance to ageing and humidity GWT Clearance and creepage IEC 60112 Tracking PTI 175V 56187* DIN 43880 DIN Rail Standard PASS N/A M3 0.65Nm Country of origin Great Britain (GB) Weight 3926909790 CMEB/1ST/KIT 27.8g CMEB/1P_ _/KIT 28.8g CMEB/1ST/E/KIT 19.6g CMEB/1P_ _/E/KIT 20.6g Enclosure type DIN Rail *Tested to ACC E SS O R I E S PA R T N U M B E R DESCRIPTION CMEB/BL/8 DIN Rail Terminal Enclosure Terminal Blank Set of 8 The CMEB blanking kit provides a way of closing off certain terminals that are not required. This ensures that the installer does not wire up the enclosure incorrectly. +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 DO NOT SCALE DRAWING B B E Commodity code PURCHASING INFORMATION SHEET 1 OF 1 A4 D Standard IEC 60998-2-1 SCREW TORQUE RAL7035 Terminals IEC 60998-2-1 - - DWG NO. Steel bright nickle plated MATERIAL. Grey IEC 60998-2-1 REVISION. - - COLOURS IP RATING P L AST I C E N C LOS U R E S 6 WA L L T H I C K N E S S 86mm x 42.4mm x 15.25mm End panels 02 5 H D REV PCB positions INDIVIDUAL SIZE DIMENSIONS 2 NAL DIMENSIONS EXTER (LXWXH) Customisation options Digital printing, CNC customised. U N I V E R SA L E N C LOS U R E S Call our sales team today on 01638 716101 CMEB Extendable DIN Rail Terminal Enclosure I N D I V I D U A L PA R T N U M B E R S (SUPPLIED IN BULK) PA R T D E S C R I P T I O N PA R T N U M B E R CMEB Solid Top Body Assembly CMEB/1SB CMEB Open Top Body Assembly CMEB/1MB CMEB End Panel CMEB/EP CMEB Extension Arm CMEB/EA CMEB Terminal Blank CMEB/BL CNMB size 1 top clear CNMB/1/PC CNMB size 1 top grey CNMB/1/PG CNMB size 1 top smoked CNMB/1/PS CNMB size 1 top red CNMB/1/PR White Clip CNMB/WHITE CLIP Black Clip CNMB/BLACK CLIP Box quantites of 25 for CMEB/1SB and CMEB/1MB To order a complete kit Select: 1x body assembly + 2x extension arms per extended body, 2x end panels per complete assembly, 1x white clip for each body, 1x black clip only per complete assembly. White clip used for surface mounting only. If ordering exclusively for DIN Rail mounting, the white clip is not required. CMEB/1SB CMEB/1MB CMEB/EP CMEB/EP P L AST I C E N C LOS U R E S C N M B / B L AC K C L I P 03 CMEB/EA CNMB/1/PC CMEB/EA CNMB/1/PG CNMB/WHITE CLIP CNMB/1/PS CMEB/BL/8 CNMB/1/PR +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2
CMEB/1PC/E/KIT 价格&库存
很抱歉,暂时无法提供与“CMEB/1PC/E/KIT”相匹配的价格&库存,您可以联系我们找货
CMEB/1PC/E/KIT
  • 1+172.22404
库存:74
CMEB/1PC/E/KIT
  • 25+132.0688125+17.14012
