CSTBP9208/3
CSTBP9208/3
    CAMDENBOSS
    CAMDENBOSS - CSTBP9208/3 - Pluggable Terminal Block, 5.08 mm, 3 Ways, 28AWG to 14AWG, 2.08 mm², Push...
CSTBP9208/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5.08mm pitch pluggable screwless terminal blocks Product overview 2-12 pole solid block Screwless connectivity Moulded in green UL94-V0, flame retardant PA66 Cable acceptance - 0.08 - 2.08mm2 (28-14 AWG) solid and stranded cable Compatible with all 5.08 pluggable male headers Pluggable female connectors Polarised mouldings US approved C Rating UL=10A/300V, IEC=20A/450V Insulation resistance 500MΩ/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0, flame retardant PA66 Spring Stainless steel Contact Bronze, Ni plated 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS POLES LENGTH CSTBP9208/2 2 10.8mm CSTBP9208/3 3 15.8mm CSTBP9208/4 4 20.9mm CSTBP9208/5 5 26.0mm CSTBP9208/6 6 31.1mm CSTBP9208/7 7 36.2mm CSTBP9208/8 8 41.2mm CSTBP9208/9 9 46.3mm CSTBP9208/10 10 51.4mm CSTBP9208/11 11 56.5mm CSTBP9208/12 12 61.6mm CSTBP9208 8.30 PA R T N O . 158 25.60 24.40 INTERFACE MODULES AND RELAY BASES 15.00 5.08 A S S O C I AT E D P R O D U C T S CSTBP9208 mates with male terminal blocks CTB9308 and CTBP9358 open and closed ended versions. C T B P 9 3 0 8 - page 66 C T B P 9 3 5 8 - page 66 C T B P 93 0 8 AO - page 66 C T B P 935 8 AO - page 66 CONNECT • • • • S P E C I F I C AT I O N 15.00 • • • • 081 TERMINAL STRIPS +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 79
CSTBP9208/3 价格&库存
很抱歉,暂时无法提供与“CSTBP9208/3”相匹配的价格&库存,您可以联系我们找货
