CTB0700/2
CTB0700/2
    CAMDENBOSS
CTB0700/2 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS 5mm Pitch High Power Rising Clamp Terminal Blocks • 2  & 3 pole double interlocking mechanism for increased strength • 4-12 pole solid block • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • 0.2-4.0mm2 (30-12AWG) solid cable • 0.2-2.5mm2 (30-12AWG) stranded cable • Guided pin alignment • Captive screw • , , approved CTB0700 SPECIFICATION Rating Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size TYPE NO. CTB0700/2 CTB0700/3 POLES 2 3 LENGTH 10mm 15mm CTB0700/4 CTB0700/5 CTB0700/6 CTB0700/7 CTB0700/8 CTB0700/9 CTB0700/10 CTB0700/11 CTB0700/12 4 5 6 7 8 9 10 11 12 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 24A/320V UL=16A/300V, VDE&IMQ=24A/450V ≥2.5kV 4kV 110°C UL94-V0 flame retardant PA66 Tinned, nickel plated brass Tinned, nickel plated brass M3 steel zinc plated, 0.5Nm ø1.5mm INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB0700/2 价格&库存
很抱歉,暂时无法提供与“CTB0700/2”相匹配的价格&库存,您可以联系我们找货
