PCB Terminal blocks
PCb
terminal
blocks
Interconnection
fuses &
Fuseholders
LEDs &
Indicators
Miniature
switches
3.81mm Pitch Ultra Low Profile Rising Clamp Terminal
2-3 pole Interlocking
4-12 pole solid block
Ultra low profile
Moulded in green UL94-V0
flame retardant PA
Professional rising
clamp terminals
0.2-1.5mm2 (30-16AWG)
solid cable
0.2-1.0mm2 (30-16AWG)
stranded cable
Captive screws
Guided pin alignment
Double interlock mechanism
for increased strength
, , , approved
limit &
Safety
switches
Specification
Rating
CTB0308
10A/130V
UL=10A, IMQ=10A, VDE=10A
1.25kV
2.5kV
110°C
UL94-V0 flame retardant PA
Tinned, nickel plated brass
Nickel plated brass
M2 steel zinc plated, 0.3Nm
ø1.1mm
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
Type No.
CTB0308/2
CTB0308/3
CTB0308/4
CTB0308/5
CTB0308/6
CTB0308/7
Poles
2
3
4
5
6
7
Length
7.6mm
11.4mm
15.2mm
19.1mm
22.9mm
26.7mm
CTB0308/8
CTB0308/9
CTB0308/10
CTB0308/11
CTB0308/12
8
9
10
11
12
30.5mm
34.3mm
38.1mm
41.9mm
45.7mm
control
products
3.81mm Pitch Ultra Low Profile 90˚ Rising Clamp Terminal
Interface
modules &
supports
relay
bases
enclosures
batteries
transformers
2-12 pole interlocking
Ultra low profile
flame retardant PA
Professional rising
clamp terminals
solid cable
stranded cable
Captive screws
, , , approved
Specification
Rating
CTB0358
10A/130V
UL=10A/300V, VDE&IMQ=10A/130V
1.25kV
2.5kV
110°C
Nickel plated brass
M2 steel zinc plated, 1.5Nm
ø1.1mm
Dielectric strength
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Type No.
CTB0358/2
CTB0358/3
CTB0358/4
CTB0358/5
CTB0358/6
CTB0358/7
CTB0358/8
CTB0358/9
CTB0358/10
CTB0358/11
CTB0358/12
5
Poles
2
3
4
5
6
7
8
9
10
11
12
Ver 1.0
EL EC T RO N IC S & ENC LOSURES
Length
7.6mm
11.4mm
15.2mm
19.1mm
22.9mm
26.7mm
30.5mm
34.3mm
38.1mm
41.9mm
45.7mm
For other dimensions see CTB0308
We operate a constant improvement policy,
our products are subject to change without notice.
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
很抱歉,暂时无法提供与“CTB0308/3”相匹配的价格&库存,您可以联系我们找货
