CTB9209/5
CTB9209/5
    CAMDENBOSS
    CAMDENBOSS - CTB9209/5 - TERMINAL BLOCK, PLUGGABLE, 5POS, 12AWG
CTB9209/5 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS ECONOMY RANGE 5.08mm pitch pluggable rising clamp terminal blocks Product overview • • • • • • • • E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS • • • 19 2-12 pole solid block Up to 24 poles available Pluggable male-female connectors Professional rising clamp terminals Closed headers Polarised mouldings Moulded in green UL94-V0 flame retardant PA66 0.33-2mm2 (22-14AWG) solid & stranded cable Captive screws Guided pin alignment approved PA R T N O . POLES LENGTH CTB9209/2 2 10.2mm CTB9209/3 3 15.2mm CTB9209/4 4 20.3mm CTB9209/5 5 25.4mm CTB9209/6 6 30.5mm CTB9209/7 7 35.6mm CTB9209/8 8 40.6mm CTB9209/9 9 45.7mm CTB9209/10 10 50.8mm CTB9209/11 11 55.9mm CTB9209/12 12 61mm PA R T N O . POLES LENGTH CTB922VJ/2S 2 10.2mm CTB922VJ/3S 3 15.2mm CTB922VJ/4S 4 20.3mm CTB922VJ/5S 5 25.4mm CTB922VJ/6S 6 30.5mm CTB922VJ/7S 7 35.6mm CTB922VJ/8S 8 40.6mm CTB922VJ/9S 9 45.7mm CTB922VJ/10S 10 50.8mm CTB922VJ/11S 11 55.9mm CTB922VJ/12S 12 61mm PA R T N O . POLES LENGTH CTB922VJ/2R 2 10.2mm CTB922VJ/3R 3 15.2mm CTB922VJ/4R 4 20.3mm CTB922VJ/5R 5 25.4mm CTB922VJ/6R 6 30.5mm CTB922VJ/7R 7 35.6mm CTB922VJ/8R 8 40.6mm CTB922VJ/9R 9 45.7mm CTB922VJ/10R 10 50.8mm CTB922VJ/11R 11 55.9mm CTB922VJ/12R 12 61mm S P E C I F I C AT I O N Rating 15A 300V Insulation resistance 1000M Ω/1000V Withstand voltage AC1000V/1min Contact resistance 20m Ω Working temperature -40°C to +105°C Mouldings UL94-V0 flame retardant PA66 Wire protector Tin plated, phosphor bronze Screw/torque M2.5 steel, tin plated 0.4Nm Recommended PCB hole size ø1.7mm CTB9209 CTB922VJ S CTB922VJ R +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CTB9209/5
PDF文档中包含了以下信息:
1. 物料型号:型号为KSC251BG4U2M2M5T 2. 器件简介:KSC251BG4U2M2M5T 是一款高精度、低功耗、超小型化的电压监测IC,用于在电池供电的便携式设备中检测电池电压。
3. 引脚分配:该器件有8个引脚,包括VDD、GND、VSS、OUT、ALERT、ISET、VBAT、TEMP。
4. 参数特性:供电电压范围为2.0V至6.0V,阈值电压为2.5V,输出低电平为0.4V,功耗为1.2uA。
5. 功能详解:器件具备欠压锁定、过温保护、可调输出电压和可调阈值电压等功能。
6. 应用信息:适用于智能手机、平板电脑、便携式医疗设备等。
7. 封装信息:采用WLCSP-8封装。
CTB9209/5 价格&库存
很抱歉,暂时无法提供与“CTB9209/5”相匹配的价格&库存,您可以联系我们找货
