CTBP0100/2
CTBP0100/2
    CAMDENBOSS
    Conn Terminal Block F 2 POS 5mm Solder ST Thru-Hole 16A
CTBP0100/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm pitch standard profile rising clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBP0100 • 2 and 3 pole double Interlocking mechanism for increased strength • Professional rising clamp terminals • Standard profile • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.6-2mm2 (22-12AWG) • Guided pin alignment • C approved US , 100 CIRCULAR CONNECTORS LENGTH Rating UL=16A/300V, VDE=20A/250V CTBP0100/2 2 10mm Insulation resistance 500M Ω/500V CTBP0100/3 3 15mm Withstand voltage AC2000V/1min CTBP0100/4 4 20mm Contact resistance 20mΩ (max) CTBP0100/5 5 25mm Working temperature -40°C to +105°C CTBP0100/6 6 30mm Moulding UL94-V0 flame retardant PA66 CTBP0100/7 7 35mm Pin/terminal Tin plated brass CTBP0100/8 8 40mm Rising clamp Brass, nickel plated CTBP0100/9 9 45mm Screw/torque M2.5 steel, zinc plated 0.4Nm CTBP0100/10 10 50mm CTBP0100/11 11 55mm CTBP0100/12 12 60mm Recommended PCB hole size ø1.5mm 151 IP68 CONNECTORS 10.2 POLES 158 INTERFACE MODULES AND RELAY BASES 14.1 PA R T N O . 3.5 S P E C I F I C AT I O N 095 WIRE TO BOARD CONNECTORS 0.9 5 0.8 5 0.6 K E Y F E AT U R E S | Standard profile CONNECT Professional rising clamp | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 23
CTBP0100/2 价格&库存
很抱歉,暂时无法提供与“CTBP0100/2”相匹配的价格&库存,您可以联系我们找货
