CTBP0110/3
CTBP0110/3
    CAMDENBOSS
    Conn Terminal Block F 3 POS 7.5mm Solder ST Thru-Hole 16A
CTBP0110/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 7. 5 m m p i t c h s t a n d a r d p r o f i l e r i s i n g clamp terminal blocks Product overview Withstand voltage POLES LENGTH UL=16A/250V, VDE=24A/250V CTBP0110/2 2 15mm 500MΩ/500V CTBP0110/3 3 22.5mm AC2000V/1min CTBP0110/4 4 30mm CTBP0110/5 5 37.5mm CTBP0110/6 6 45mm CTBP0110/7 7 52.5mm CTBP0110/8 8 60mm CTBP0110/9 9 67.5mm CTBP0110/10 10 75mm CTBP0110/11 11 82.5mm CTBP0110/12 12 90mm 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Wire protector Screw/torque Recommended PCB hole size Tin plated brass Phosphor bronze, nickel plated M2.5 Steel, zinc plated 0.4Nm ø1.5mm 151 IP68 CONNECTORS 10.3 PA R T N O . Contact resistance Pin/terminal 100 CIRCULAR CONNECTORS 158 INTERFACE MODULES AND RELAY BASES 14.1 Insulation resistance 095 WIRE TO BOARD CONNECTORS 3.5 Rating 081 TERMINAL STRIPS CTBP0110 • 2 and 3 pole double interlocking mechanism for increased strength • Professional rising clamp terminals • Standard profile • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.6-2mm2 (22-12AWG) • Guided pin alignment • C approved US , S P E C I F I C AT I O N PCB TERMINAL BLOCKS 5.4 7.5 3.75 K E Y F E AT U R E S | Professional rising clamp CONNECT Low profile | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 39
CTBP0110/3 价格&库存
很抱歉,暂时无法提供与“CTBP0110/3”相匹配的价格&库存,您可以联系我们找货
