CTBP0308/3
CTBP0308/3
    CAMDENBOSS
    CAMDENBOSS - CTBP0308/3 - LOW PROFILE RISING CLAMP TERMINAL BLOCK
CTBP0308/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 3.81mm low profile vertical rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 CTBP0308 • • • • • • • • • 2 and 3 pole Interlocking 4-12 pole solid block Ultra low profile Moulded in green UL94-V0 flame retardant PA Professional rising clamp terminals 0.32-1.6mm2 (28-16AWG) cable Captive screws Guided pin alignment Double interlock mechanism for increased strength • C approved US , IP68 CONNECTORS Impulse withstand voltage 2.0kV/1min CTBP0308/3 3 11.4mm CTBP0308/4 4 15.2mm Working temperature -40°C + 105°C CTBP0308/5 5 19.1mm Moulding UL94-V0 flame retardant PA66 CTBP0308/6 6 22.9mm Pin/terminal Tinned, nickel plated brass CTBP0308/7 7 26.7mm CTBP0308/8 8 30.5mm CTBP0308/9 9 34.3mm CTBP0308/10 10 38.1mm CTBP0308/11 11 41.9mm CTBP0308/12 12 45.7mm Rising clamp Screw/torque Recommended PCB hole size Tinned, nickel plated brass M2 steel zinc plated, 0.2Nm ø1.3mm 1.91 3.81(xx-1) 3.81 7.40 7.62mm PCB layout 3.81xx A 0.35 8.50 UL=15A/300V, VDE=15A/250V 3.75 LENGTH 2 7.40 POLES CTBP0308/2 3.75±0.3 0.50 3.50±0.3 INTERFACE MODULES AND RELAY BASES PA R T N O . Rating Ø1.3 158 S P E C I F I C AT I O N Section: A-A K E Y F E AT U R E S | Professional rising clamp CONNECT Ultra low profile | Double interlock mechanism 16 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 0.90 1.91 3.81 3.81(xx-1) A
CTBP0308/3 价格&库存
很抱歉,暂时无法提供与“CTBP0308/3”相匹配的价格&库存,您可以联系我们找货
