P C B T E R M I N A L B LO C KS
S TA N D A R D
SCREWLESS
PLUGGABLES
002
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
5.08mm 45° rising clamp terminal
blocks
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
CTBP3008
• 2-12 pole solid block
• 45° cable entry
• Moulded in green UL94-V0 flame retardant
PA
• Professional rising clamp terminals
• Cable acceptance - 0.13-2.08mm2 (26-14AWG)
• Captive screw
• C
approved
US ,
151
Working temperature
-40°C to +105°C
Moulding
UL94-V0 flame retardant PA66
Pin/terminal
Tinned, nickel plated brass
Rising clamp
Screw/torque
M3 steel zinc plated, 0.5Nm
Recommended PCB
hole size
ø1.6mm
LENGTH
2
11.08mm
CTBP3008/3
3
16.16mm
CTBP3008/4
4
21.32mm
CTBP3008/5
5
26.32mm
CTBP3008/6
6
31.4mm
CTBP3008/7
7
36.48mm
CTBP3008/8
8
41.56mm
CTBP3008/9
9
46.64mm
CTBP3008/10
10
51.72mm
CTBP3008/11
11
56.8mm
12
61.88mm
K E Y F E AT U R E S
CONNECT
38
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers12.1
Vers
5.08
3.00
Ø1
.4
5.08xx+0.92
CTBP3008/12
45° mounting | Interlocking
5.08(xx-1)
12.14
2.0kV/1min
POLES
CTBP3008/2
12.14
Impulse withstand
voltage
PA R T N O .
PCB layout
A
6.07
0.50
3.50±0.4
INTERFACE
MODULES AND
RELAY BASES
UL=15A/300V, VDE=24A/250V
11.14
158
S P E C I F I C AT I O N
Rating
6.07
IP68 CONNECTORS
1.00
A
5.08
55.08(xx-1)
3.00
很抱歉,暂时无法提供与“CTBP3008/2”相匹配的价格&库存,您可以联系我们找货
