CTBP5000/3
CTBP5000/3
    CAMDENBOSS
    n/a
CTBP5000/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm pitch low profile screw terminal blocks Product overview • • • • • • • • • 081 TERMINAL STRIPS CTBP5000 2 and 3 pole interlocking Wire protector terminals Low profile Moulded in green UL94-V0 flame retardant PA66 Cable acceptance - 0.6-1.6mm2 (2214AWG) Guided pin alignment Test probe facility Anti solder wicking terminal approved US , C 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS S P E C I F I C AT I O N PA R T N O . POLES LENGTH Rating UL=16A/250V, VDE=24A/250V CTBP5000/2 2 10mm 500M Ω/500V CTBP5000/3 3 15mm Withstand voltage AC2000V/1min CTBP5000/4 4 20mm Contact resistance 20mΩ (max) CTBP5000/5 5 25mm Working temperature -40°C to +105°C CTBP5000/6 6 30mm UL94-V0 flame retardant PA66 CTBP5000/7 7 35mm CTBP5000/8 8 40mm CTBP5000/9 9 45mm CTBP5000/10 10 50mm CTBP5000/11 11 55mm CTBP5000/12 12 60mm Pin/terminal Wire protector Screw/torque Recommended PCB hole size Tin plated brass Phosphor bronze, nickel plated M2.5 steel, zinc plated 0.4Nm ø1.2mm 4 0.5 INTERFACE MODULES AND RELAY BASES 3.8 Moulding 158 0.5 7.5 10 Insulation resistance 1 5 K E Y F E AT U R E S | F l a m e r e t a r d a n t PA 6 6 CONNECT Wire protector terminals | Interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 17
CTBP5000/3 价格&库存
很抱歉,暂时无法提供与“CTBP5000/3”相匹配的价格&库存,您可以联系我们找货
