CTBP9308/4AO
CTBP9308/4AO
    CAMDENBOSS
    CAMDENBOSS - CTBP9308/4AO - Terminal Block, Open Ended, Header, 5.08 mm, 4 Ways, Through Hole Vertic...
CTBP9308/4AO 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5.08mm pitch pluggable rising clamp terminal blocks Product overview • • • • • • • • • • • 081 TERMINAL STRIPS S P E C I F I C AT I O N 2-24 pole solid block Professional rising clamp terminals Moulded in green UL94-V0 flame retardant PA66 Cable acceptance - 0.32 to 1.6mm2 (28-14AWG) solid and stranded cable Pluggable male and female connectors Open and closed headers Horizontal and vertical female plug styles Polarised mouldings Anti solder wicking Captive screws and guided pin alignment approved US , C Rating UL=15A/300V, VDE=20A/450V Insulation resistance 500M Ω/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Mouldings UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Rising clamp Brass, nickel plated Screw/torque M3 steel, zinc plated 0.5Nm Recommended PCB hole size ø1.7mm 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS Female connector 10.2mm CTBP9208/3 3 15.2mm CTBP9208/4 4 20.3mm CTBP9208/5 5 25.4mm CTBP9208/6 6 30.5mm CTBP9208/7 7 35.6mm CTBP9208/8 8 40.6mm CTBP9208/9 9 45.7mm CTBP9208/10 10 50.8mm CTBP9208/11 11 55.9mm CTBP9208/12 12 61mm CTBP9208 158 18.1 LENGTH 2 8.3 POLES CTBP9208/2 INTERFACE MODULES AND RELAY BASES 5.08 15.05 PA R T N O . Female vertical connector (standard) 10.2mm CTBP92VJ/3S 3 15.2mm CTBP92VJ/4S 4 20.3mm CTBP92VJ/5S 5 25.4mm CTBP92VJ/6S 6 30.5mm CTBP92VJ/7S 7 35.6mm CTBP92VJ/8S 8 40.6mm CTBP92VJ/9S 9 45.7mm CTBP92VJ/10S 10 50.8mm CTBP92VJ/11S 11 55.9mm CTBP92VJ/12S 12 61mm CTBP92VJ S 5.08 26 LENGTH 2 8.3 POLES CTBP92VJ/2S 12.6 PA R T N O . Female vertical connector (reversed) CTBP92VJ/3R 3 15.2mm CTBP92VJ/4R 4 20.3mm CTBP92VJ/5R 5 25.4mm CTBP92VJ/6R 6 30.5mm CTBP92VJ/7R 7 35.6mm CTBP92VJ/8R 8 40.6mm CTBP92VJ/9R 9 45.7mm CTBP92VJ/10R 10 50.8mm CTBP92VJ/11R 11 55.9mm CTBP92VJ/12R 12 61mm CTBP92VJ R 5.08 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 CONNECT 10.2mm 26 LENGTH 2 8.3 POLES CTBP92VJ/2R 12.6 PA R T N O . 65 P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 LENGTH 2 11.6mm CTBP9308/3 3 16.6mm CTBP9308/4 4 21.7mm CTBP9308/5 5 26.8mm CTBP9308/6 6 31.9mm CTBP9308/7 7 37.0mm CTBP9308/8 8 42.0mm CTBP9308/9 9 47.1mm CTBP9308/10 10 52.2mm CTBP9308/11 11 57.3mm CTBP9308/12 12 62.4mm CTBP9308 7.8 3.9 5.08 1 PCB mounting male horizontal connector (closed ended) PA R T N O . POLES LENGTH CTBP9358/2 2 11.6mm CTBP9358/3 3 16.6mm CTBP9358/4 4 21.7mm CTBP9358/5 5 26.8mm CTBP9358/6 6 31.9mm CTBP9358/7 7 37.0mm CTBP9358/8 8 42.0mm CTBP9358/9 9 47.1mm CTBP9358/10 10 52.2mm CTBP9358/11 11 57.3mm CTBP9358/12 12 62.4mm CTBP9358 5.08 4 7.8 1 3 12 2 INTERFACE MODULES AND RELAY BASES POLES CTBP9308/2 8.5 095 PA R T N O . 8.5 TERMINAL STRIPS 4 081 PCB mounting male vertical connector (closed ended) 12 PCB TERMINAL BLOCKS PCB mounting male vertical connector (open ended) CTBP9308/3AO 3 15.2mm CTBP9308/4AO 4 20.3mm CTBP9308/5AO 5 25.4mm CTBP9308/6AO 6 30.5mm CTBP9308/7AO 7 35.6mm CTBP9308/8AO 8 40.6mm CTBP9308/9AO 9 45.7mm CTBP9308/10AO 10 50.8mm CTBP9308/11AO 11 55.9mm CTBP9308/12AO 12 61mm CTBP9308 AO 8.5 10.2mm 7.8 3.9 5.08 1 1 4 LENGTH 2 2 POLES CTBP9308/2AO 12 PA R T N O . 66 LENGTH 2 10.2mm CTBP9358/3AO 3 15.2mm CTBP9358/4AO 4 20.3mm CTBP9358/5AO 5 25.4mm CTBP9358/6AO 6 30.5mm CTBP9358/7AO 7 35.6mm CTBP9358/8AO 8 40.6mm CTBP9358/9AO 9 45.7mm CTBP9358/10AO 10 50.8mm CTBP9358/11AO 11 55.9mm CTBP9358/12AO 12 61mm CTBP9358 AO +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 8.5 POLES CTBP9358/2AO 5.08 7.8 1 4 12 PA R T N O . 2 CONNECT PCB mounting male horizontal connector (open ended)
CTBP9308/4AO 价格&库存
很抱歉,暂时无法提供与“CTBP9308/4AO”相匹配的价格&库存,您可以联系我们找货
