CTBPD96HJ/10
CTBPD96HJ/10
    CAMDENBOSS
    CAMDENBOSS - CTBPD96HJ/10 - DIN Rail Mount Terminal Block, 10 Ways, 28 AWG, 14 AWG, 2.5 mm², Screw, ...
CTBPD96HJ/10 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 5.08mm DIN rail mounted inverted/ reverse terminal blocks Product overview • • • • • • • • PCB TERMINAL BLOCKS 081 TERMINAL STRIPS S P E C I F I C AT I O N Horizontal orientations Polarized moldings Can be reversed on DIN clips Also available in 5.08mm pitch Molded in green UL94-V0 flame retardant PA 66 2.5mm2 (28-14AWG) approved US , C 6-12 poles standard (13-24 also available) Rating UL=15A/300V IEC 20A/450V Insulation resistance 500MΩ/500V Withstand Voltage AC2000V/1min Contact Resistance 20mΩ (max) Working Temperature -40°C to 105+°C Mouldings UL94-V0 Flame retardant PA66 Pin/Terminal Brass, Tin plated Rising Clamp Brass, nickel plated Screw/Torque M3 Steel, zinc plated 0.5Nm 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS DIN rail mounting male vertical POLES LENGTH CTBPD96VJ/6 6 32.0mm CTBPD96VJ/7 7 37.1mm CTBPD96VJ/8 8 42.2mm CTBPD96VJ/9 9 47.2mm CTBPD96VJ/10 10 52.3mm CTBPD96VJ/11 11 57.4mm CTBPD96VJ/12 12 62.5mm CTBPD96VJ 20.6 32 5.08 158 17.3 17.3 INTERFACE MODULES AND RELAY BASES 33.9 16.5 11.6 3.6 PA R T N O . 42.5 11.6 20.6 DIN rail mounting male vertical flanged LENGTH B 41.8mm CTBPD96VJ/7FL 7 37.1mm 46.9mm CTBPD96VJ/8FL 8 42.2mm 52.0mm CTBPD96VJ/9FL 9 47.2mm 57.0mm CTBPD96VJ/10FL 10 52.3mm 62.1mm CTBPD96VJ/11FL 11 57.4mm 67.2mm CTBPD96VJ/12FL 12 62.5mm 72.3mm CTBPD96VJ/FL Length B Length A 20.6 17.3 33.9 LENGTH A 32.0mm 21.5 12.3 11.6 3.6 POLES 6 5.08 PA R T N O . CTBPD96VJ/6FL 42.5 11.6 20.6 DIN rail mounting male horizontal LENGTH CTBPD96HJ/6 6 32.0mm CTBPD96HJ/7 7 37.1mm CTBPD96HJ/8 8 42.2mm CTBPD96HJ/9 9 47.2mm CTBPD96HJ/10 10 52.3mm CTBPD96HJ/11 11 57.4mm CTBPD96HJ/12 12 62.5mm CTBPD96HJ/FL 19.2 31.8 5.08 1 20.2 12.3 11.6 8.5 11.6 42.5 CONNECT POLES 20.5 32.6 PA R T N O . 19.2 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 69
CTBPD96HJ/10 价格&库存
很抱歉,暂时无法提供与“CTBPD96HJ/10”相匹配的价格&库存,您可以联系我们找货
