BIM/ADAPTER
BIM/ADAPTER
    CAMDENBOSS
    CAMDENBOSS - BIM/ADAPTER - BIM ADAPTER, ENCLOSURE, PCB MOUNT
BIM/ADAPTER 数据手册
U N I V E R SA L E N C LOS U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES 2000 series general purpose ABS cases Product overview 292 UNIVERSAL ENCLOSURES BIM2001 Extensive range of electronic enclosures with solid ABS lid, designed for a broad range of applications. 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES • Lid and base moulded in ABS • Lid mounted by four M3 machine screws • Brass inserts in base for repetitive removal of the lid • Polished finish for ease of cleaning • Excellent properties for machining • Integral mounting guides to accept 1.6mm PCBs • Available with clear lid on request (subject to MOQ) • Available in other colours on request (subject to MOQ) • 2000 series has been designed to meet the requirements of IP54 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 ROOM SENSOR ENCLOSURES S P E C I F I C AT I O N Materials Lid and base high impact ABS UL94-HB New colours - ABS UL94-V0 Operating temperature Resistant to temperatures between -5°C and 80°C Protection class 2000 series has been designed to meet the requirements of IP54 Standard colours Grey (GY), black (BK), ivory (WH), orange (ORG) Standard unit includes Base and lid 4x M3 machine screws Options (MOQ”s apply) Different colours Clear lid Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) H L L W 370 GREY B L AC K I VO RY ORANGE LENGTH W I DT H HEIGHT *BIM2008/18-GY/GY *BIM2008/18-BLK/BLK *BIM2008/18-WH/WH *BIM2008/18-ORG/ORG 55mm 55mm 42mm *BIM2000/10-GY/GY *BIM2000/10-BLK/BLK *BIM2000/10-WH/WH *BIM2000/10-ORG/ORG 75mm 50mm 27mm BIM2001/11-GY/GY BIM2001/11-BLK/BLK BIM2001/11-WH/WH BIM2001/11-ORG/ORG 85mm 56mm 39mm BIM2002/12-GY/GY BIM2002/12-BLK/BLK BIM2002/12-WH/WH BIM2002/12-ORG/ORG 100mm 50mm 25mm BIM2003/13-GY/GY BIM2003/13-BLK/BLK BIM2003/13-WH/WH BIM2003/13-ORG/ORG 112mm 62mm 31mm BIM2007/17-GY BIM2007/17-BLK - - 112mm 62mm 31mm BIM2004/14-GY/GY BIM2004/14-BLK/BLK BIM2004/14-WH/WH BIM2004/14-ORG/ORG 120mm 65mm 40mm RTM2030/30-GY RTM2030/30-BLK - - 142mm 80mm 30mm BIM2005/15-GY/GY BIM2005/15-BLK/BLK BIM2005/15-WH BIM2005/15-ORG/ORG 150mm 80mm 50mm BIM2006/16-GY/GY BIM2006/16-BLK/BLK BIM2006/16-WH/WH BIM2006/16-ORG/ORG 190mm 110mm 60mm BIM2009/19-GY/GY - - - 250mm 200mm 64mm CUSTOM SIZED ENCLOSURES P L AST I C E N C LOS U R E S * BIM2008/18 and BIM2000/10 are supplied with self tapping screws. +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers Vers 2D1 297 U N I V E R SA L E N C LOS U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 2000 series general purpose ABS cases - flanged Product overview 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES BIM2000 For applications requiring surface or wall mounting and protection against dust and water ingress. Provides extra security once mounted by restricting access to the screws in the lid. • • • • • Flanged IP65 lid and base moulded in ABS Lid mounted by four M3 machine screws Polished finish for ease of cleaning Excellent properties for machining Integral mounting guides to accept 1.6mm PCBs • Plastic standoffs in lid for PCB mounting • 2000 series flanged has been designed to meet the requirements of IP54 and IP65 with gasket accessory 367 ROOM SENSOR ENCLOSURES S P E C I F I C AT I O N 370 Materials Lid and base high impact ABS Operating temperature Resistant to temperatures of up to 80°C Protection class 2000 series flanged has been designed to meet the requirements of IP54 or additionally, IP65 with the gasket accessory Standard colours Grey and black Standard unit includes Base and flanged lid 4x M3 screws - required torque setting 10 cNm (0.1Nm) Available accessories IP65 gasket kits BIM adapter (PCB adapter for horizontal PCB mounting) CUSTOM SIZED ENCLOSURES P L AST I C E N C LOS U R E S IP65 gasket kits 298 GREY B L AC K LENGTH W I DT H HEIGHT PA R T N O . DESCRIPTION BIM2008/IP-GY BIM2008/IP-BLK 75mm 57mm 43mm SA00 2000/IP gasket BIM2000/IP-GY BIM2000/IP-BLK 95mm 52mm 28mm SA1 2001/IP gasket kit BIM2001/IP-GY BIM2001/IP-BLK 105mm 58mm 40mm SA2 2002/IP gasket kit BIM2002/IP-GY BIM2002/IP-BLK 120mm 52mm 26mm SA34 2003/IP & 2004/IP gasket kit BIM2003/IP-GY BIM2003/IP-BLK 132mm 64mm 32mm SA50 2005/IP & 2030/IP gasket kit BIM2004/IP-GY BIM2004/IP-BLK 140mm 67mm 41mm SA6 2006/IP gasket kit BIM2030/IP-GY BIM2030/IP-BLK 162mm 82mm 31mm SA8 2008/1P gasket BIM2005/IP-GY BIM2005/IP-BLK 170mm 82mm 51mm BIM2006/IP-GY BIM2006/IP-BLK 210mm 112mm 61mm K E Y F E AT U R E S IP65 flanged lid | PCB mounting | Base moulded in ABS +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 12 2D FM 28614 EMS 613558 U N I V E R SA L E N C LOS U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES 2000 series general purpose ABS cases - lugged lid Product overview 292 UNIVERSAL ENCLOSURES BIM2005 Electronic enclosures with lugged lid, for broad range of surface mounting applications. Provides extra security once mounted by restricting access to the screws in the lid. 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES • • • • • Lugged lid and base moulded in ABS Lid mounted by four M3 machine screws Polished finish for ease of cleaning Excellent properties for machining Integral mounting guides to accept 1.6mm PCBs • 2000 series has been designed to meet the requirements of IP54 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 S P E C I F I C AT I O N ROOM SENSOR ENCLOSURES Materials Lid and base high impact ABS Operating temperature Resistant to temperatures of up to 80°C Protection class 2000 series has been designed to meet the requirements of IP54 Standard colours Grey (GY), black (BLK), ivory (WH) Standard unit includes Base and lugged lid 4x M3 machine screws Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) 370 CUSTOM SIZED ENCLOSURES GREY B L AC K I VO RY LENGTH W I DT H HEIGHT BIM2003/LUG-GY/GY BIM2003/LUG-BLK/BLK BIM2003/LUG-WH/WH 132mm 62mm 31mm BIM2004/LUG-GY/GY BIM2004/LUG-BLK/BLK BIM2004/LUG-WH/WH 140mm 65mm 40mm BIM2005/LUG-GY/GY BIM2005/LUG-BLK/BLK BIM2005/LUG-WH/WH 172mm 80mm 50mm K E Y F E AT U R E S P L AST I C E N C LOS U R E S Polished finish | Horizontal PCB mounting | Moulded in ABS +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 2D1 Vers 299 U N I V E R SA L E N C LOS U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 2000 series general purpose ABS cases - deep profile Product overview 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 ROOM SENSOR ENCLOSURES 370 CUSTOM SIZED ENCLOSURES BIM2005/25 Multi-purpose enclosures for application where tall electrical components require housing. The deep profile 2000 series provides maximum utilisation of the internal volume. • Deep profile lid and base moulded in ABS • Brass inserts in base for repeated removal of the lid • Excellent properties for machining • Integral mounting guides in base to accept 1.6mm PCB’s • 2000 series has been designed to meet the requirements of IP54 S P E C I F I C AT I O N Materials Lid and base high impact ABS Operating temperature Resistant to temperatures of up to 80°C Protection class 2000 series has been designed to meet the requirements of IP54 Standard colours Grey (GY), black (BLK) Standard unit includes Base and deep profile lid 4x M3 machine screws Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) GREY B L AC K LENGTH W I DT H HEIGHT BIM2002/22-GY/GY BIM2002/22-BLK/BLK 100mm 50mm 40mm BIM2004/24-GY/GY BIM2004/24-BLK/BLK 120mm 65mm 60mm BIM2005/25-GY/GY BIM2005/25-BLK/BLK 150mm 80mm 76mm BIM2006/26-GY/GY BIM2006/26-BLK/BLK 190mm 110mm 90mm 2000 DEEP PROFILE CLEAR LID BIM2005/25 Extensive range of electronic enclosures for applications that require visible electronics and high profile components. Suitable for both electronic and electrical applications. • Deep profile lid moulded in transparent high impact ABS • Brass inserts in base for repeated removal of the lid • Integral mounting guides in base to accept 1.6mm PCB’s • 2000 series has been designed to meet the requirements of IP54 P L AST I C E N C LOS U R E S S P E C I F I C AT I O N 300 Materials Base high impact ABS Lid transparent high impact ABS Operating temperature Resistant to temperatures of up to 80°C Protection class IP54 2000 series has been designed to meet the requirements of IP54 Standard colours Grey (GY), black (BLK) and ivory (WH) Standard unit includes Base and clear deep profile lid 4x M3 machine screws Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) GREY B L AC K WHITE LENGTH W I DT H HEIGHT BIM2002/22-GY/CLR BIM2002/22-BLK/CLR BIM2002/22-WH/CLR 100mm 50mm 40mm BIM2004/24-GY/CLR BIM2004/24-BLK/CLR BIM2004/24-WH/CLR 120mm 65mm 60mm BIM2005/25-GY/CLR BIM2005/25-BLK/CLR BIM2005/25-WH/CLR 150mm 80mm 76mm BIM2006/26-GY/CLR BIM2006/26-BLK/CLR BIM2006/26-WH/CLR 190mm 110mm 90mm +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 2D 1 FM 28614 EMS 613558 U N I V E R SA L E N C LOS U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES 2000 series general purpose ABS cases - EMC Product overview 292 UNIVERSAL ENCLOSURES BIM2003 A range of high frequency EMC compliant enclosures for shielding electronic equipment. 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES • • • • • Lid and base moulded in ABS Graphite dark grey paint finish Electromagnetic compatibility EMC coating Lid mounted by four M3 machine screws Brass inserts in base for repeated removal of the lid • Excellent properties for machining • Integral mounting guides to accept 1.6mm PCBs • 2000 series has been designed to meet the requirements of IP54 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 ROOM SENSOR ENCLOSURES S P E C I F I C AT I O N Materials Lid and base high impact ABS Operating temperature Resistant to temperatures of up to 80°C Protection class 2000 series has been designed to meet the requirements of IP54 Standard colours Graphite dark grey Standard unit includes Base and lid 4x M3 machine screws Available accessories BIM adapter (PCB adapter for horizontal PCB mounting) 370 CUSTOM SIZED ENCLOSURES GREY LENGTH W I DT H HEIGHT BIM2008/18-EMI/RFI 55mm 55mm 42mm BIM2000/10-EMI/RFI 75mm 50mm 27mm BIM2001/11-EMI/RFI 85mm 56mm 39mm BIM2002/12-EMI/RFI 100mm 50mm 25mm BIM2003/13-EMI/RFI 112mm 62mm 31mm BIM2007/17-EMI/RFI 112mm 62mm 31mm BIM2004/14-EMI/RFI 120mm 65mm 40mm BIM2030/30-EMI/RFI 142mm 80mm 30mm BIM2005/15-EMI/RFI 150mm 80mm 50mm BIM2006/16-EMI/RFI 190mm 110mm 60mm BIM2009/19-EMI/RFI 250mm 200mm 64mm K E Y F E AT U R E S P L AST I C E N C LOS U R E S EMC graphite paint finish | EMC compliant | Moulded in ABS ACC E SS O R I E S BIM adapter • For horizontal PCB mounting PA R T N O . DESCRIPTION BIM/ADAPTER BIM adapter (PCB adapter for horizontal PCB mounting) • Suitable for all BIM2000 series enclosures +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 2D1 Vers 301
BIM/ADAPTER 价格&库存
很抱歉,暂时无法提供与“BIM/ADAPTER”相匹配的价格&库存,您可以联系我们找货
