19'' CABINETS
Accessories
UNIVERSAL
ENCLOSURES
Cantilever Tray
HAND
HELD
CASES
HEAVY
DUTY
ENCLOSURES
DIN
RAIL
BOXES
INTERFACE
SUPPORTS
TYPE NO.
CAX2TY180
CAX2TY280
CAX2TY350
CAX2TY400
U
2U
2U
2U
2U
DEPTH
180mm
280mm
350mm
400mm
Cantilever Telescopic Tray
CONTROL
STATIONS
DIECAST
& METAL
BOXES
DESKTOP &
INSTRUMENT
CASES
Manufactured in steel, 1.5mm thick.
19'' assembly with four anchoring points on the front sections
Recommended maximum static load: 10/20 Kg
Standard ventilation slots
Front fastening height 2U
One tray with mounting hardware
Standard depths 180, 280, 350, 400mm
Grey graphite expoxy paint, anthracite - RAL 7016
1 tray (screws not included)
TYPE NO.
CAXCTT280
U
2U
Ideal for holding keyboards
19''assembly with four anchoring points on the front sections
Recommended maximum static load- 10kg
Standard depths 280mm
Finish: Black epoxy paint
Telescopic guide rails nickel plated
1 Tray, 1 pair telescopic guides, 1 front handle
Easy assembly is attached to the rack at four anchoring points with M6 bolts
Attachment points adaptable to variations in the depth of the 19'' sections
Recommended maximum static load: 60 Kg
Colour epoxy paint, anthracite - RAL 7016
Attached to rack by two anchoring points with M6 bolts
Made of steel, 2mm thick
Zinc plated coating
1 Pair of guides and assembly hardware
DEPTH
280mm
POTTING
BOXES
19''
ENCLOSURES
Side Mount Tray
19"
CABINETS
WIDTH
DEPTH
350mm
550mm
DEVELOPMENT
BOARD
ENCLOSURES
TYPE NO.
CAXSMT350
CAXSMT550
CUSTOM
SIZED
ENCLOSURES
Front Guides Mounting
424mm
424mm
RACK
600 Deep
800 Deep
CUSTOM
SERVICES
TYPE NO.
CAXFMG001
SDESCRITPTION
Front guide Mounting
85
Ver 1.0
EL EC T RO N IC S & ENC LOSURES
We operate a constant improvement policy,
our products are subject to change without notice.
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
19'' CABINETS
Clip-on Support Guides
TYPE NO.
CAXCSG345
CAXCSG545
Quick attachment to the rack, without bolts
Zinc plated coated
1 pair of guides
UNIVERSAL
ENCLOSURES
HAND
HELD
CASES
DEPTH
345mm
545mm
HEAVY
DUTY
ENCLOSURES
Bolt-on Support Guides
TYPE NO.
CAXBSG345
CAXBSG545
DIN
RAIL
BOXES
Height adjustable with standard position indicator
Zinc plated coated
1 pair of guides and assembly hardware
INTERFACE
SUPPORTS
DEPTH
345mm
545mm
CONTROL
STATIONS
Cable Guides Clamps
DIECAST
& METAL
BOXES
• Manufactured in steel
• Standard finish: Epoxy paint simillar to RAL 9004
• Pack quantity x1
TYPE NO.
CAX19CGC1
CAX19CGC2
DESKTOP &
INSTRUMENT
CASES
DESCRITPTION
1U Guide
2U Guide
POTTING
BOXES
1U Cable Clamp Panel
19"
ENCLOSURES
TYPE NO.
CAX19CCP1
19'' panel for guiding and distributing wires
Manufactured in steel 1.5mm thick
Finish: Black epoxy paint similar to RAL 9004
1 Panel assembly hardware
19"
CABINETS
DEVELOPMENT
BOARD
ENCLOSURES
U
1
Multi Functional Cross Members
Attached to the lateral structure of rack, they can be used as a cable guide
and provide additional anchoring points to the 19'' sections.
CUSTOM
SERVICES
• Manufactured using 1mm thick steel
• Epoxy paint, graphite grey
• 1 pair and hardware mounting
TYPE NO.
CAXMFM600
CAXMFM800
CUSTOM
SIZED
ENCLOSURES
DEPTH
600mm
800mm
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
86
Ver 1.0 Iss 1
19'' CABINETS
Vertical Wiring Distributor
Ideal for the vertical distribution of wiring in the 800mm wide racks.
Built -in clamps and integrated outlets for high density of wiring. Possibility to
assembly extra clamps at the back side.
UNIVERSAL
ENCLOSURES
HAND
HELD
CASES
HEAVY
DUTY
ENCLOSURES
TYPE NO.
CAXVWD42U
DEPTH
42U
• Manufactured in 2mm thick steel
• 1 pair of vertical distributors and assembly hardware
19'' Silver Front Panel
DIN
RAIL
BOXES
• Manufactured in aluminium, 3mm thick, clear anodised
• Vented and solid profiles
INTERFACE
SUPPORTS
STANDARD FRONT VENTED FRONT
CONTROL
STATIONS
DIECAST
& METAL
BOXES
DESKTOP &
INSTRUMENT
CASES
CAX19SPS1
CAX19SPS2
CAX19SPS3
CAX19SPS4
CAX19SPS5
CAX19SPS6
CAX19SPS9
CAX19VPS1
CAX19VPS2
CAX19VPS3
CAX19VPS4
CAX19VPS5
CAX19VPS6
CAX19VPS9
U
1U
2U
3U
4U
5U
6U
9U
HEIGHT
43.6mm
88.1mm
132.5mm
177.0mm
221.5mm
265.9mm
399.2mm
B
5.9mm
5.9mm
37.7mm
37.7mm
37.7mm
37.7mm
37.7mm
19'' Panel Anthracite
• Manufactured in steel (RAL 7016)
POTTING
BOXES
19''
ENCLOSURES
19"
CABINETS
STANDARD FRONT
CAX19SPA1
CAX19SPA2
CAX19SPA3
CAX19SPA4
CAX19SPA5
CAX19SPA6
CAX19SPA9
VENTED FRONT
CAX19VPA1
CAX19VPA2
CAX19VPA3
CAX19VPA4
CAX19VPA5
CAX19VPA6
CAX19VPA9
U
1U
2U
3U
4U
5U
6U
9U
HEIGHT (MM)
43.6mm
88.1mm
132.5mm
177.0mm
221.5mm
265.9mm
399.2mm
DEVELOPMENT
BOARD
ENCLOSURES
CUSTOM
SIZED
ENCLOSURES
CUSTOM
SERVICES
87
Ver 1.0 Iss 2
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
19'' CABINETS
Attachment Set
• Nickel-plated M6 x 15mm locking bolt with combi slotted/pozi head, PA
washer, M6 caged nut with stainless-steel cage
• Pack of 4
HAND
HELD
CASES
DESCRITPTION
TYPE NO.
CAX000001
UNIVERSAL
ENCLOSURES
Attachment set
HEAVY
DUTY
ENCLOSURES
Baying Kit
• Fast, effective side-assembly system for attaching two or more racks
• Standard packaging: 8 threaded screws and 4 intermediate sleeves
DIN
RAIL
BOXES
INTERFACE
SUPPORTS
DESCRITPTION
TYPE NO.
CAX000002
CONTROL
STATIONS
Baying Kit
DIECAST
& METAL
BOXES
LX Wheel Kit
• Set of 4 double rotating wheels with rubber rolling band or polyamide
• Bracket made of stamped steel, with double roll of balls
• Maximum dynamic load acceptable per set: 2400N/240 Kg )
TYPE NO.
CLX000001
POTTING
BOXES
DESCRITPTION
LX Wheel Kit
19"
ENCLOSURES
CamRack LX Earthing Kit
Series of 6 ground lines with straight/ring faston terminals at the ends. Allows all
movable parts of rack to be earthed. Made of 2mm copper cable (3.5 insulator)
• Cable length 200/400 mm
• 6 ground wires and assembly hardware
TYPE NO.
CAXEARTH1
DESKTOP &
INSTRUMENT
CASES
19"
CABINETS
DEVELOPMENT
BOARD
ENCLOSURES
DESCRIPTION
CUSTOM
SIZED
ENCLOSURES
CUSTOM
SERVICES
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
88
Ver 1.0
19'' CABINETS
Base Plate - Plain
Made of steel 1.5mm, its 3-part design allows for quick assembly.
UNIVERSAL
ENCLOSURES
HAND
HELD
CASES
HEAVY
DUTY
ENCLOSURES
DIN
RAIL
BOXES
• Made of steel 2mm thick
RACK
WIDTH
60mm
600mm
800mm
800mm
TYPE NO.
CAXBPPL66
CAXBPPL68
CAXBPPL86
CAXBPPL88
RACK
DEPTH
600mm
800mm
600mm
800mm
QX/WX Fan Tray
Fan tray with 2 fans. Suitable for use with the QX and WX rack.
INTERFACE
SUPPORTS
CONTROL
STATIONS
TYPE NO.
CAXFT2FAN
DIECAST
& METAL
BOXES
LX Fan Tray
Fan tray with 4 or 6 fans.
Suitable for use with the LX 600 deep and 800 deep racks.
DESKTOP &
INSTRUMENT
CASES
POTTING
BOXES
TYPE NO.
19''
ENCLOSURES
CAXFT4FAN
CAXFT6FAN
RACK
DEPTH
600 Deep
800 Deep
19"
CABINETS
DEVELOPMENT
BOARD
ENCLOSURES
CUSTOM
SIZED
ENCLOSURES
CUSTOM
SERVICES
89
Ver 1.0
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
很抱歉,暂时无法提供与“CAXCSG345”相匹配的价格&库存,您可以联系我们找货
