19'' CABINETS
Attachment Set
• Nickel-plated M6 x 15mm locking bolt with combi slotted/pozi head, PA
washer, M6 caged nut with stainless-steel cage
• Pack of 4
type no.
CAX000001
hand
held
cases
SDescritption
Attachment set
Front Guides Mounting
heavy
duty
enclosures
type no.
CAXFMG001
Attached to rack by two anchoring points with M6 bolts.
Made of steel, 2mm thick
Zinc plated coating
1 Pair of guides and assembly hardware
DIN
Rail
Boxes
Interface
supports
SDescritption
Front guide Mounting
control
stations
LX Wheel Kit
• Set of 4 double rotating wheels with rubber rolling band or polyamide.
• Bracket made of stamped steel, with double roll of balls
• Maximum dynamic load acceptable per set: 2400N/240 Kg )
type no.
CLX000001
universal
Enclosures
diecast
& metal
boxes
Desktop &
Instrument
cases
Descritption
LX Wheel Kit
Potting
Boxes
Cable Guides Clamps
• Manufactured in steel
• Standard finish: Epoxy paint simillar to RAL 9004
• Pack quantity x1
19"
ENCLOSURES
19"
CABINETS
type no.
CAX19CGC1
CAX19CGC2
Descritption
1U Guide
2U Guide
DEVELOPMENT
BOARDS
custom
sized
enclosures
Custom
Services
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement policy,
our products are subject to change without notice.
Ver 1.0
ELEC T RON IC S & ENC LOSURES
19'' CABINETs
Side Mount Tray
universal
Enclosures
hand
held
cases
heavy
duty
enclosures
DIN
Rail
Boxes
type no.
CAXSMT350
CAXSMT550
WIDTH
424mm
424mm
DEPTH
350mm
550mm
Manufactured in steel, 1.5mm thick.
Easy assembly is attached to the rack at four anchoring points with M6 bolts
Attachment points adaptable to variations in the depth of the 19'' sections
Recommended maximum static load: 60 Kg
Standard ventilation slots
Colour epoxy paint, anthracite - RAL 7016
One tray with mounting hardware
19'' assembly with four anchoring points on the front sections
Recommended maximum static load: 10/20 Kg
Front fastening height 2U
Standard depths 180, 280, 350, 400mm
Grey graphite expoxy paint, anthracite - RAL 7016
Cantilever Tray
type no.
CAX2TY180
CAX2TY280
CAX2TY350
CAX2TY400
U
2U
2U
2U
2U
DePTH
180mm
280mm
350mm
400mm
Interface
supports
• 1 tray (screws not included)
control
stations
diecast
& metal
boxes
Cantilever Telescopic Tray
type no.
CAXCTT280
U
2U
DePTH
280mm
Desktop &
Instrument
cases
Potting
Boxes
19''
Enclosures
Ideal for holding keyboards
19''assembly with four anchoring points on the front sections
Recommended maximum static load- 10kg
Standard depths 280mm
Finish: Black epoxy paint
Telescopic guide rails nickel plated
1 Tray, 1 pair telescopic guides, 1 front handle
19"
CABINETS
Clip-on Support Guides
Development
BOARDS
Quick attachment to the rack, without bolts
Zinc plated coated
1 pair of guides
custom
sized
enclosures
Custom
Services
type no.
CAXCSG345
CAXCSG545
Depth
345mm
545mm
Ver 1.0 Iss 1
EL EC T RO N IC S & ENC LOSURES
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
很抱歉,暂时无法提供与“CAXSMT350”相匹配的价格&库存,您可以联系我们找货
