CBRPF-CLR-C
CBRPF-CLR-C
    CAMDENBOSS
CBRPF-CLR-C 数据手册
RASPBERRY PI STYLE ENCLOSURES Enclosure universal Enclosures hand held cases heavy duty enclosures DIN Rail Boxes No screws, no glue – just add your Raspberry Pi filling! • Designed to house the Raspberry Pi and via clip-in grooves - NO SCREWS REQUIRED! • All cut-outs are pre-cut into the case - NO MODS REQUIRED! • Wall mountable • Supplied with four Rubber feet • Supplied with LED light pipes (excluding clear) • Supplied with four actuators • High Gloss Finish • Compatible with the Raspberry Pi Camera • Pi Camera slot can be opened with a flat headed screwdriver Interface supports control stations diecast & metal boxes Desktop & Instrument cases Material: • Thickness 3mm: HB Rated • Coloured Materials: High Impact Polystyrene (HIPS) • Carbon Fibre Finish: Acrylic Capped ABS • Light Pipes: Transparent Acrylic Raspberry Pi and PiFace TM Digital assemblies not included Available in a range of colours: Gloss Finish Potting Boxes 19" Enclosures Crystal Clear White *Carbon Fibre Lilac Blue Red * Carbon fibre finish:Acrylic capped ABS PiFace 19" Subracks Custom sized enclosures CB PART NO. CBRPF-CLR CBRPF-WHT CBRPF-CAR CBRPF-LIL CBRPF-BLU CBRPF-RED COLOURS Crystal Clear White Carbon Fibre Lilac Blue Red TM CB PART NO. CBRPF-ACC Digital Enclosure Accessories DESCRIPTION Includes 2 Light pipes 4 Actuators 4 Rubber feet Custom Services Ver 1.0 Iss 1 EL EC T RO N IC S & ENC LOSURES We operate a constant improvement policy, our products are subject to change without notice. +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
CBRPF-CLR-C 价格&库存
很抱歉,暂时无法提供与“CBRPF-CLR-C”相匹配的价格&库存,您可以联系我们找货
