CFTBN/3
CFTBN/3
    CAMDENBOSS
CFTBN/3 数据手册
CFTBN Call our sales team today on +44 (0)1638 716101 5 x 2 0 m m F u s e d Te r m i n a l B l o c k s Product Overview • 1 - 5 pole terminal strip with 5x20mm fuseholder • Integral spare fuse carrier • Interlocking fuseholder with CFTBN/1 • Anti-rotation spigot • Cable entry 4mm2 (2.5mm2 with wire protector) • Wire protector on fuse terminal as standard • Wire protectors on earth pole to order • UL approved - UL 1059 • CSA approved Te c h n i c a l D a t a S P E C I F I C AT I O N Rating Fuseholder 250V AC / Terminal 450V AC Current Rating Fuseholder 13A / Terminal 20A Moulding UL94-V0 Flame Retardant PA66 Terminal Brass, nickel plated Fuse clip Phosphor bronze Wire protector Stainless steel Operating Temperature -20° to 120°C Fuse Size 5x20mm glass or ceramic Screws Steel zinc plated M3, 0.5Nm GWIT 775°C Cable CSA 4mm2 (2.5mm2 with wire protector) F U S E D T E R M I N A L B LO C KS P/ N R E F. 01 Te c h n i c a l D r a w i n g CFTBN/5 DESCRIPTION CFTBN/x Fused Terminal Block, M3 fixing hole and screw/washer CFTBN/xNE Fused Terminal Block, M3 fixing hole CFTBN/xWP Fused Terminal Block, wire protected terminals, no M3 fixing hole CFTBN/xEWP Fused Terminal Block, wire protected terminals, M3 fixing hole with screw/washer CFTBN/xEWPG Fused Terminal Block, wire protected terminals/Earth, M3 fixing hole with screw/washer FUSE WIRE PROTECTOR • Accessory for CFTBN CFTBN/1 16.1 mm • • Screw/dust protection CFTBN/2 20.6 mm • • Easily cut to required size CFTBN/3 30.8 mm • • • CFTBN/4 40.7 mm • • • CFTBN/5 50.9 mm • • • CFTBN/3NE 30.8 mm • CFTBN/4NE 40.7 mm • CFTBN/5NE 50.9 mm • CFTBN/3NS 30.8 mm • • CFTBN/4NS 40.7 mm • • CFTBN/5NS 50.9 mm • • CFTBN/2WP 20.6 mm • • CFTBN/3WP 30.8 mm • • CFTBN/4WP 40.7 mm M3 FIXING HOLE EARTH WIRE PROTECTED • WIRE PROTECTED TERMINALS Te r m i n a l C o v e r B O DY DIMENSIONS (LENGTH) PA R T N O . FIXING SCREW & WA S H E R S GENERAL TOLERANCE OF ±0.20mm • • PA R T N O . POLES CFTBN/3C 3 pole cover CFTBN/5C 5 pole cover CFTBN/5WP 50.9 mm • CFTBN/3EWP 30.8 mm • • • • CFTBN/4EWP 40.7 mm • • • • R E L AT E D PRODUCTS CFTBN/5EWP 50.9 mm • • • • CFB0520F Glass 5x20mm quick blow fuses CFTBN/3EWPG 30.8 mm • • • • • CFB0520T Glass 5x20mm time delay fuses CFTBN/4EWPG 40.7 mm • • • • • CFB0521CF Ceramic 5x20mm quick blow fuses CFTBN/5EWPG 50.9 mm • • • • • CFB0521CT Ceramic 5x20mm time delay fuses +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 5 DESCRIPTION
CFTBN/3 价格&库存
很抱歉,暂时无法提供与“CFTBN/3”相匹配的价格&库存,您可以联系我们找货
CFTBN/3
  • 1+112.34448
  • 50+109.57440
  • 100+107.44997
库存:3770
