CHDAPB025/6
CHDAPB025/6
    CAMDENBOSS
    CAMDENBOSS - CHDAPB025/6 - Mounting Bracket, Size 2, M5x12 Screw, Plastic, 23 mm, 24 mm
CHDAPB025/6 数据手册
H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES X6 series electrical knockout enclosures - polycarbonate Product overview 292 UNIVERSAL ENCLOSURES CHDX6 • Screw type lid with knockouts on the base • Moulded in high quality polycarbonate • Pillars in the base can be used for PCB mounting or DIN rail mounting, etc. • Gasket moulded into the enclosure lid • Clear lid option available • Captive, polyamide lid screws included • Larger sizes include two brass inserts at either end of the base, suitable for DIN rails • Wall mounting accessories available • X6 series meets the requirements of IP67 (equivalent to NEMA 6) • IK08 impact tested 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES S P E C I F I C AT I O N Materials Polycarbonate UL94-V0 Operating temperature -40°C to + 110°C Protection class X6 series has been tested and meets the requirements of IP67, IK08 Standard colours Grey, transparent lid option Standard unit includes Box, lid, 4 screws Available accessories Mount plates and wall mounts 367 VERSATILE IOT AND SENSOR ENCLOSURES 370 CUSTOM SIZED ENCLOSURES SOLID LID CLEAR LID LENGTH W I DT H HEIGHT CHDX6-221 CHDX6-221C 110mm 80mm 70mm CHDX6-222 CHDX6-222C 110mm 80mm 85mm CHDX6-223 CHDX6-223C 130mm 80mm 70mm CHDX6-224 CHDX6-224C 130mm 80mm 85mm CHDX6-225 CHDX6-225C 180mm 80mm 70mm CHDX6-226 CHDX6-226C 180mm 80mm 85mm CHDX6-227 CHDX6-227C 250mm 80mm 70mm CHDX6-228 CHDX6-228C 250mm 80mm 85mm CHDX6-229 CHDX6-229C 175mm 127mm 75mm CHDX6-230 CHDX6-230C 175mm 127mm 100mm K E Y F E AT U R E S P L AST I C E N C LOS U R E S I P 6 7 r a t e d e n c l o s u r e | I K 0 7/ 0 8 i m p a c t t e s t e d | M e t r i c s i z e d k n o c k o u t s +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers Vers41 321 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES X6 series electrical knockout enclosures - ABS Product overview 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES CHDX6 • Screw type lid with knockouts on the base • Moulded in high quality ABS • Pillars in the base can be used for PCB mounting or DIN rail mounting, etc. • Gasket moulded into the enclosure lid • Clear lid option available • Captive, polyamide lid screws included • Larger sizes include two brass inserts at either end of the base, suitable for DIN rails • Wall mounting accessories available • X6 series meets the requirements of IP67 (equivalent to NEMA 6) • IK08 impact tested S P E C I F I C AT I O N 367 VERSATILE IOT AND SENSOR ENCLOSURES 370 CUSTOM SIZED ENCLOSURES Materials ABS UL94-HB Operating temperature -40°C- to + 70°C Protection class X6 series has been tested and meets the requirements of IP67, IK08 Standard colours Grey, transparent lid option Standard unit includes Box, lid, 4 screws Available accessories Mount plates and wall mounts SOLID LID CLEAR LID LENGTH W I DT H HEIGHT CHDX6-321 CHDX6-321C 110mm 80mm 70mm CHDX6-322 CHDX6-322C 110mm 80mm 85mm CHDX6-323 CHDX6-323C 130mm 80mm 70mm CHDX6-324 CHDX6-324C 130mm 80mm 85mm CHDX6-325 CHDX6-325C 180mm 80mm 70mm CHDX6-326 CHDX6-326C 180mm 80mm 85mm CHDX6-327 CHDX6-327C 250mm 80mm 70mm CHDX6-328 CHDX6-328C 250mm 80mm 85mm CHDX6-329 CHDX6-329C 175mm 127mm 75mm CHDX6-330 CHDX6-330C 175mm 127mm 100mm K E Y F E AT U R E S P L AST I C E N C LOS U R E S H i g h q u a l i t y A B S | I P 6 7 r a t e d e n c l o s u r e | I K 0 7/ 0 8 i m p a c t t e s t e d 322 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 4 1 FM 28614 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES ACC E SS O R I E S Ve n t s t o f i t X 6 , X 7 and X8 enclosures 292 • Vents in two sizes for heat extraction • The vent includes a gasket for water resistant applications • Designed to meet the requirements of IP34 PA R T N O . CUTOUT DIAMETER M AT E R I A L CHDA201V 63 Polycarbonate CHDA202V 88 Polycarbonate CHDA301V 63 ABS CHDA302V 88 ABS UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES Mounting brackets to fit X6, X7 and X8 enclosures • Brackets to mount each enclosure to any surface/wall • See cross reference page 328 to select the correct size for your enclosure PA R T N O . SIZE CHDAPB014/4 1 Size 1 Bracket, 4x12 S/T Screw, 4pc kit CHDAPB015/4 1 Size 1 Bracket, 5x12 S/T Screw, 4pc kit CHDAPB025/4 2 Size 2 Bracket, M5x12 Screw, 4pc kit CHDAPB025/6 2 Size 2 Bracket, M5x12 Screw, 6pc kit CHDAPB026/6 2 Size 2 Bracket, M6x12 Screw, 6pc kit 348 DEVELOPMENT BOARD ENCLOSURES 367 VERSATILE IOT AND SENSOR ENCLOSURES 370 CUSTOM SIZED ENCLOSURES Mounting plates to fit X6, X7 and X8 enclosures • Material: Steel • Mounting plates for each enclosure available PA R T N O . L E N G T H mm W I DT H CHDASMP21 65mm 95mm CHDASMP22 65mm 115mm CHDASMP23 65mm 165mm CHDASMP24 65mm 235mm CHDASMP25 101mm 161mm CHDASMP26 159mm 159mm CHDASMP27 159mm 248mm CHDASMP28 248mm 348mm CHDASMP29 295mm 395mm CHDASMP30 85mm 232mm CHDASMP32 129mm 179mm CHDASMP33 129mm 224mm CHDASMP34 170mm 266mm CHDASMP35 179mm 179mm CHDASMP36 216mm 316mm CHDASMP37 262mm 262mm CHDASMP38 265mm 365mm CHDASMP39 358mm 458mm CHDASMP40 450mm 555mm CHDASMP41 550mm 755mm CHDASMP42 248mm 248mm CHDASMP43 248mm 308mm CHDASMP44 232mm 535mm CHDASMP45 345mm 535mm CHDASMP46 159mm 348mm CHDASMP49 65mm 65mm P L AST I C E N C LOS U R E S • See cross reference page 329 to select the correct size for your enclosure +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers 12 Vers 327 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES 292 UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES ACC E SS O R I E S Dual door to fit the X8 enclosure PA R T N O . KIT INCLUDES CHDX807DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws • Easy to assemble, sturdy construction CHDX808DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws • See cross reference page 328 to select the correct size for your enclosure CHDX810DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX811DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX812DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX813DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws CHDX814DD 4 legs, 1 door, 1 door handle, 1 frame, 8 screws • Dual door avaliable for some sizes 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 VERSATILE IOT AND SENSOR ENCLOSURES Lock to fit the X8 enclosure • One or two locks can be fitted, depending on security level required • See cross reference page 328 to select the correct size for your enclosure • Moulded in high quality polycarbonate PA R T N O . SIZE CHDA01IL 1 CHDA02IL 2 CHDA03IL 3 CHDA04IL 4 370 P L AST I C E N C LOS U R E S CUSTOM SIZED ENCLOSURES 328 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD CASES DIECAST DIECAST ACCESSORIES ACCESSORIES ACC E SS O R I E S F O R X 6 , X 7 A N D X 8 S E R I E S C H DX 8 1 4 D D C H DX 8 1 3 D D C H DX 8 1 2 D D 292 C H DX 8 1 1 D D C H DX 8 0 1 0 D D C H DX 8 0 8 D D C H DX 8 0 7 D D C H DA 0 4 I L DUAL DOOR C H DA 0 3 I L C H DA 0 2 I L C H DA 0 1 I L C H DA P B 0 2 6 / 6 LO C KS C H DA P B 0 2 5 / 6 C H DA P B 0 2 5 /4 UNIVERSAL ENCLOSURES 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES CHDX6-221 CHDX6-321  CHDX6-222 CHDX6-322  CHDX6-223 CHDX6-323  CHDX6-224 CHDX6-324  CHDX6-225 CHDX6-325  CHDX6-226 CHDX6-326  CHDX6-227 CHDX6-327  CHDX6-228 CHDX6-328  CHDX6-229 CHDX6-329  CHDX6-230 CHDX6-330  CHDX7-221 CHDX7-321  CHDX7-222 CHDX7-322  CHDX7-223 CHDX7-323  CHDX7-224 CHDX7-324  CHDX7-225 CHDX7-325  CHDX7-226 CHDX7-326  CHDX7-227 CHDX7-327  CHDX7-228 CHDX7-328  CHDX7-229 CHDX7-329  CHDX7-230 CHDX7-330  CHDX7-231 CHDX7-331  CHDX7-232 CHDX7-332  CHDX7-237 CHDX7-327 CHDX8-221 CHDX8-321   CHDX8-222 CHDX8-322   CHDX8-223 CHDX8-333   CHDX8-224 CHDX8-324   CHDX8-225 CHDX8-325   CHDX8-226 CHDX8-326   CHDX8-227 CHDX8-327   CHDX8-228 CHDX8-328   CHDX8-229 CHDX8-329  CHDX8-230 CHDX8-330   CHDX8-231 CHDX8-331   CHDX8-232 CHDX8-332   CHDX8-233 CHDX8-333  CHDX8-234 CHDX8-334 CHDX8-235 CHDX8-335   CHDX8-236 CHDX8-336   342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES 367 VERSATILE IOT AND SENSOR ENCLOSURES 370 CUSTOM SIZED ENCLOSURES            P L AST I C E N C LOS U R E S ABS C H DA P B 0 1 5 /4 P O LY W/ M O U N T C H DA P B 0 1 4 /4 E N C L O S U R E PA R T N O . *Add 'c' suffix for clear lid versions +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 1 Vers 2 329 H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S 268 HANDHELD DIECASTCASES ACCESSORIES M O U N T I N G P L AT E S E N C L O S U R E PA R T N O . 318 HEAVY DUTY AND ELECTRICAL ENCLOSURES 342 DESKTOP AND INSTRUMENT CASES 348 DEVELOPMENT BOARD ENCLOSURES CHDX7-229 CHDX7-329 CHDX7-230 CHDX7-330 367 VERSATILE IOT AND SENSOR ENCLOSURES CHDX7-231 CHDX7-331 CHDX7-232 CHDX7-332 CHDX8-221 CHDX8-321 370  CHDX8-222 CHDX8-322 CUSTOM SIZED ENCLOSURES  CHDX8-223 CHDX8-323  CHDX8-224 CHDX8-324  CHDX8-225 CHDX8-325 CHDX8-226 CHDX8-326 CHDX8-227 CHDX8-327  CHDX8-228 CHDX8-328  CHDX8-229 CHDX8-329 CHDX8-230 CHDX8-330 CHDX8-231 CHDX8-331 CHDX8-232 CHDX8-332 CHDX8-233 CHDX8-333 CHDX8-234 CHDX8-334 CHDX8-235 CHDX8-335  CHDX8-236 CHDX8-336  C H DA S M P 4 6 CHDX7-328 C H DA S M P 4 5  CHDX7-228 C H DA S M P 4 4 CHDX7-327 C H DA S M P 4 3  CHDX7-227 C H DA S M P 4 2 CHDX7-326 C H DA S M P 4 1 CHDX7-226 C H DA S M P 4 0 CHDX7-325 C H DA S M P 3 9 CHDX7-324 CHDX7-225 C H DA S M P 3 8 CHDX7-224 C H DA S M P 3 7  C H DA S M P 3 6 CHDX7-323 C H DA S M P 3 5  CHDX7-223 C H DA S M P 3 4 CHDX7-322 C H DA S M P 3 3 CHDX7-222 C H DA S M P 3 2 CHDX7-321 C H DA S M P 3 1  CHDX7-221 C H DA S M P 3 0 CHDX6-330 C H DA S M P 2 9  CHDX6-230 C H DA S M P 2 8 CHDX6-329 UNIVERSAL ENCLOSURES C H DA S M P 2 7 CHDX6-229 292 C H DA S M P 2 6 ABS C H DA S M P 2 5 P O LY                 P L AST I C E N C LOS U R E S *Add 'c' suffix for clear lid versions 330 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 1 FM 28614
CHDAPB025/6 价格&库存
很抱歉,暂时无法提供与“CHDAPB025/6”相匹配的价格&库存,您可以联系我们找货
