CHTB10/3N
CHTB10/3N
    CAMDENBOSS
CHTB10/3N 数据手册
TERMINAL STRIPS 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS High temperature resistant connection blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 S P E C I F I C AT I O N • • • • Porcelain body rated to 1000°C Inserts rated to 350°C 1 to 4 poles available 3, 3.5, 4.4 and 6mm insert diameter sizes • approved CIRCULAR CONNECTORS CHTB Voltage (max) 1 Pole 2-4 pole 250V AC 450V AC Working temperature 5°C to 350°C Insert Nickel-plated brass Screws Zinc-plated steel CQ-15 Length Height 151 IP68 CONNECTORS Pitch Width 158 INTERFACE MODULES AND RELAY BASES POLES POLES MAX. CURRENT INSERT DIAMETER MAX. CONDUCTOR: MAX. CONDUCTOR: RIGID FLEXIBLE LENGTH HEIGHT MOUNTING HOLE SIZE MOUNTING HOLE SIZE DIAMETER SCREW HEAD TERMINAL: PITCH SCREWS CHTB4/1N 1 32A 3mm 4mm2 4mm2 10mm 18mm 17mm N/A N/A N/A M2.6 CHTB4/2N 2 32A 3mm 4mm2 4mm2 21.5mm 18mm 17mm 4.5mm 6.9mm 11.5mm M2.6 CHTB4/3N 3 32A 3mm 4mm2 4mm2 33mm 18mm 17mm 4.5mm 6.9mm 11.5mm M2.6 CHTB4/4N 4 32A 3mm 4mm2 4mm2 44.5mm 18mm 17mm 4.5mm 6.9mm 11.5mm M2.6 CHTB6/1N 1 41A 3.5mm 6mm2 4mm2 11mm 20mm 17.5mm N/A N/A N/A M3 CHTB6/2N 2 41A 3.5mm 6mm2 4mm2 23.5mm 20mm 17.5mm 4.5mm 7.5mm 12.5mm M3 CHTB6/3N 3 41A 3.5mm 6mm2 4mm2 36mm 20mm 17.5mm 4.5mm 7.5mm 12.5mm M3 CHTB6/4N 4 41A 3.5mm 6mm2 4mm2 48.5mm 20mm 17.5mm 4.5mm 7.5mm 12.5mm M3 CHTB10/1N 1 57A 4.4mm 10mm2 6mm2 12mm 22mm 18mm N/A N/A N/A M3.5 CHTB10/2N 2 57A 4.4mm 10mm2 6mm2 26mm 22mm 18mm 5mm 8.5mm 14mm M3.5 CHTB10/3N 3 57A 4.4mm 10mm2 6mm2 40mm 22mm 18mm 5mm 8.5mm 14mm M3.5 CHTB10/4N 4 57A 4.4mm 10mm2 6mm2 54mm 22mm 18mm 5mm 8.5mm 14mm M3.5 CHTB16/1N 1 76A 6mm 16mm2 10mm2 16mm 30mm 23mm N/A N/A N/A M4 CHTB16/2N 2 76A 6mm 16mm2 10mm2 34mm 30mm 23mm 5mm 9mm 17.5mm M4 CHTB16/3N 3 76A 6mm 16mm2 10mm2 52mm 30mm 23mm 5mm 9mm 17.5mm M4 CHTB16/4N 4 76A 6mm 16mm2 10mm2 70mm 30mm 23mm 5mm 9mm 17.5mm M4 CONNECT 108 W I DT H +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 1 Vers 4
CHTB10/3N 价格&库存
很抱歉,暂时无法提供与“CHTB10/3N”相匹配的价格&库存,您可以联系我们找货
CHTB10/3N
  • 1+18.75532
库存:146
