CNMB/12/2
CNMB/12/2
    CAMDENBOSS
CNMB/12/2 数据手册
D I N R A I L E N C LOS U R E S DIN Rail modular enclosures Product overview CNMB • Designed to meet the requirements of DIN 43880 • Snap fit modular design for ease of assembly and custom kitting • Base fits 35mm (EN60715) DIN Rail or directly to flat surface • Moulded in light grey UL94-V0 flame retardant polycarbonate • Carries up to 3 PCBs horizontally or 2 vertically • Base PCB screw size - No.6 x 1/4” self tapping screw • Snap fit terminal cover options for IP20 finger protection • Snap in top covers available in grey, clear, transparent red and smoked • Standard enclosure consists of base, top and rail/wall clips • Open top as standard, solid top, vented and extended wall options available • Covers and terminal guards ordered separately and can be supplied in kits • Easily customised covers and terminal guards and CNMB base • Clear, smoked and red covers are moulded in PC UL94-V2 • Grey covers are PC UL94-V0 • Enclosed base offers isolation from DIN Rail • Front panel (covers) ideal for screen printing and recessed solid top for labels and membranes • Other colours and EMC shielding available to order B OX L E N G T H A H O R I Z O N TA L P C B S I Z E S B C VERTICAL PCB SIZES E D CNMB/1- 17.5mm 86.5x14mm 57x14mm 41.8x14mm 34x59.6mm 40x14.8mm CNMB/2- 36mm 86.5x33mm 57x32mm 42x32mm 34x59.6mm 40x33mm CNMB/3- 53.4mm 86.5x50mm 57x49mm 42x49mm 34x59.6mm 40x50mm CNMB/4- 71.2mm 86.5x68mm 57x67mm 42x67mm 34x59.6mm 40x68mm CNMB/5- 88mm 86.5x84mm 57x83mm 42x83mm 34x59.6mm 40x84mm CNMB/6- 106.2mm 86.5x103mm 57x102mm 42x102mm 34x59.6mm 40x103mm CNMB/9- 159.2mm 86.5x156mm 57x155.5mm 42x155mm 34x59.6mm 40x155mm CNMB/12- 212.1mm 86.5x208mm 57x207mm 42x207mm 34x59.6mm 40x208mm For exposed terminal positions both sides, add /2 to part number (e.g. CNMB/5/2) For exposed terminal positions one side only, add /1 to part number (e.g. CNMB/5/1). Please note, this is only available as standard in sizes 5, 6 and 9 Box supplied with open top as standard For solid recessed top used for membrane keypads or clear covers to enclose labels, add ST to part number (e.g. CNMB/3ST/2) For cooling vents both sides add V to part number (e.g. CNMB/3V/2) For extended side walls which meet the lower PCB behind terminals, add W to part number (e.g. CNMB/3W/2) - terminal guards do not fit extended wall versions Combinations of body types are available (e.g. solid top with vented sides). These may be subject to MOQ Vented sides (V) Extended walls (W) Vertical PCB positions Horizontal PCB sizes D I N R A I L E N C LOS U R E S Solid top (ST) Horizontal PCB positions D E B C A +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers4 1 393 D I N R A I L E N C LOS U R E S Double row terminals/covers both sides y y y X 71.2 y 9/2 y 6/2 y X 53.4 X 21.3 88.0 X 113.8 X 60.6 5/2 y X 36.0 X 42.6 4/2 y y 3/2 y X X y y y 90.0 (pitch of wall mounting holes in DIN Rail clips) 98 (1/2 to 4/2) 2/2 1/2 X 17.5 X y X X X 30.2 106.2 56.9 159.2 Single row terminals/covers on one side X X X y 9/1 y X 212.1 99.8 99.8 y 113.8 6/1 y X MINAL GUARDS TER 93 (pitch of wall mounting holes in din rail clips) y 12/2 (pitch of wall mounting holes in DIN Rail clips) 99.8 (5/2 to 12/2) y 60.6 30.2 106.0 X (pitch of wall mounting holes in DIN Rail clips) 167 56.9 159.0 Solid D E CNMB/1/TGS Solid 17.5mm 15.0mm 14.3mm CNMB/2/TGS Solid 35.5mm 29.9mm 13.8mm CNMB/3/TGS Solid 52.8mm 45.5mm 13.8mm CNMB/4/TGS Solid 70.6mm 59.9mm 13.8mm CNMB/5/TGS Solid 87.6mm 79.5mm 13.8mm CNMB/x/TGS A 20.0 A E D 20.0 STYLE 8 PA R T N O . 0.8 1.5 For 6, 9 and 12 size module use CNMB/3TGS 5.08mm pitch perforated CNMB/x/TG508P STYLE A D E CNMB/1/TG508P Perforated 17.5mm 15.0mm 14.3mm CNMB/2/TG508P Perforated 35.5mm 29.9mm 13.8mm CNMB/3/TG508P Perforated 52.8mm 45.5mm 13.8mm CNMB/4/TG508P Perforated 70.6mm 59.9mm 13.8mm CNMB/5/TG508P Perforated 87.6mm 79.5mm 13.8mm A E D 8 PA R T N O . 0.8 1.5 For 6, 9 and 12 size module use CNMB/3/TG508P 394 A B C D E 3 17.5mm 2.3mm 2.3mm 15.0mm 14.3mm CNMB/2/TG508 Pre-drilled 6 35.5mm 0.9mm 2.7mm 29.9mm 13.8mm CNMB/3/TG508 Pre-drilled 9 52.8mm 2.3mm 2.3mm 45.5mm 13.8mm CNMB/4/TG508 Pre-drilled 12 70.6mm 2.7mm 5.8mm 59.9mm 13.8mm CNMB/5/TG508 Pre-drilled 15 87.6mm 2.7mm 5.8mm 79.5mm 13.8mm A CNMB/x/TG508 B 7.3 POLES Pre-drilled C E D 20.0 STYLE CNMB/1/TG508 8 PA R T N O . 0.8 1.5 For 6, 9 and 12 size module use CNMB/3/TG508 STYLE POLES A B C D E Pre-drilled 2 17.5mm 2.3mm 2.3mm 15.0mm 14.3mm CNMB/2/TG750 Pre-drilled 4 35.5mm 0.9mm 2.7mm 29.9mm 13.8mm CNMB/3/TG750 Pre-drilled 6 52.8mm 2.3mm 2.3mm 45.5mm 13.8mm CNMB/4/TG750 Pre-drilled 8 70.6mm 2.7mm 5.8mm 59.9mm 13.8mm CNMB/5/TG750 Pre-drilled 10 87.6mm 2.7mm 5.8mm 79.5mm 13.8mm For 6, 9 and 12 size module use CNMB/3/TG750 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers 2 1 A CNMB/x/TG750 B C E D 20.0 PA R T N O . CNMB/1/TG750 7.3 7. 5 m m p i t c h p r e - d r i l l e d 8 D I N R A I L E N C LOS U R E S 5.08mm pitch pre-drilled 0.8 1.6 D I N R A I L E N C LOS U R E S 1 0.1 6 m m p i tc h p re - d r i l l e d POLES A B C D E Pre-drilled 2 17.5mm 1.0mm 1.0mm 15.0mm 14.3mm CNMB/2/TG100 Pre-drilled 3 35.5mm 0.9mm 0.9mm 29.9mm 13.8mm CNMB/3/TG100 Pre-drilled 5 52.8mm 1.0mm 1.0mm 45.5mm 13.8mm CNMB/4/TG100 Pre-drilled 6 70.6mm 2.7mm 2.7mm 59.9mm 13.8mm CNMB/5/TG100 Pre-drilled 7 87.6mm 2.7mm 5.8mm 79.5mm 13.8mm C B E D 8 20.0 STYLE CNMB/1/TG100 7.3 A CNMB/x/TG100 PA R T N O . 0.8 1.5 For 6, 9 and 12 size module use CNMB/3/TG100 RJ45 5.08mm pitch perforated CNMB/x/TGRJ45 PA R T N O . STYLE POLES A B C D E CNMB/3/TGRJ45 Perforated 5 52.8mm 1.0mm 1.0mm 45.5mm 13.8mm A 12.50 19.80 B Can be used on sizes 3, 6, 9 and 12 C D E 1 5 19.80 1.50 MINI USB 5.08mm pitch perforated CNMB/x/TGMINIUSB PA R T N O . STYLE POLES A B C D E CNMB/3/TGMINIUSB Perforated 7 52.8mm 1.0mm 1.0mm 45.5mm 13.8mm A C 12.50 B 19.80 Can be used on sizes 3, 6, 9 and 12 E D 5 19.80 1 1.50 USB 5.08 pitch perforated CNMB/x/TGUSB PA R T N O . STYLE POLES A B C D E CNMB/3/TGUSB Perforated 6 52.8mm 1.0mm 1.0mm 45.5mm 13.8mm A 19.80 Can be used on sizes 3, 6, 9 and 12 B 8 D 5 C E 1 1.50 COV E R S Standard covers S M O K E D T R A N S PA R E N T C L E A R T R A N S PA R E N T GREY SIZE CNMB/1/PR CNMB/1/PS CNMB/1/PC CNMB/1/PG 1 CNMB/2/PR CNMB/2/PS CNMB/2/PC CNMB/2/PG 2 CNMB/3/PR CNMB/3/PS CNMB/3/PC CNMB/3/PG 3 CNMB/4/PR CNMB/4/PS CNMB/4/PC CNMB/4/PG 4 CNMB/5/PR CNMB/5/PS CNMB/5/PC CNMB/5/PG 5 CNMB/6/PR CNMB/6/PS CNMB/6/PC CNMB/6/PG 6 CNMB/9/PR CNMB/9/PS CNMB/9/PC CNMB/9/PG 9 - - CNMB/12/PC CNMB/12/PG 12 D I N R A I L E N C LOS U R E S R E D T R A N S PA R E N T +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers Vers21 395 D I N R A I L E N C LOS U R E S Curved covers R E D T R A N S PA R E N T S M O K E D T R A N S PA R E N T C L E A R T R A N S PA R E N T GREY SIZE CNMB/2/PRC CNMB/2/PSC CNMB/2/PCC CNMB/2/PGC 2 CNMB/3/PRC CNMB/3/PSC CNMB/3/PCC CNMB/3/PGC 3 CNMB/4/PRC CNMB/4/PSC CNMB/4/PCC CNMB/4/PGC 4 CNMB/5/PRC CNMB/5/PSC CNMB/5/PCC CNMB/5/PGC 5 CNMB/6/PRC CNMB/6/PSC CNMB/6/PCC CNMB/6/PGC 6 CNMB/9/PRC CNMB/9/PSC CNMB/9/PCC CNMB/9/PGC 9 EXTENDED HEIGHT MODULES • 16mm high CNMB/x/E • Accepts curved hinged cover only PA R T N O . W I DT H SIZE CNMB/2/E 34.7mm 2 • Adds an additional horizontal PCB slot CNMB/3/E 52.0mm 3 • Does not fit on solid top CNMB’s CNMB/4/E 70.0mm 4 CNMB/5/E 86.5mm 5 CNMB/6/E 104.5mm 6 CNMB/9/E 157.7mm 9 Curved hinged covers R E D T R A N S PA R E N T C L E A R T R A N S PA R E N T GREY SIZE CNMB/2/HPRC CNMB/2/HPCC CNMB/2/HPGC 2 CNMB/3/HPRC CNMB/3/HPCC CNMB/3/HPGC 3 CNMB/4/HPRC CNMB/4/HPCC CNMB/4/HPGC 4 CNMB/5/HPRC CNMB/5/HPCC CNMB/5/HPGC 5 CNMB/6/HPRC CNMB/6/HPCC CNMB/6/HPGC 6 CNMB/9/HPRC CNMB/9/HPCC CNMB/9/HPGC 9 For use with extended height module only E N C LOS U R E K I TS CNMB/x/KIT KIT D I N R A I L E N C LOS U R E S STANDARD 396 • Each kit contains one grey panel cover and a selection of solid and perforated terminal guards KIT • Kits of the most frequently used components are available to order * For size 6, 9 and 12, multiple ‘size 3’ terminal guards are supplied. For example size 6 requires 2x ‘size 3’ guards per side. EXTENDED HEIGHT Kits are also available for vented, solid top and extended wall bodies e.g. CNMB/2ST/KIT. Extended wall kits do not come with terminal guards +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 1 TERMINAL GUARDS EXTENSION MODULE COMPONENT COV E R KIT PART NO. /PG /TG508P /TGS CNMB/1/KIT 1 2 1 - CNMB/2/KIT 1 2 1 - /E CNMB/3/KIT 1 2 1 - CNMB/4/KIT 1 2 1 - CNMB/5/KIT 1 2 1 - CNMB/6/KIT 1 4* 2* - CNMB/9/KIT 1 6* 3* - CNMB/12/KIT 1 8* 4* - COMPONENT COV E R TERMINAL GUARDS EXTENSION MODULE KIT PART NO. /HPCC /TG508P /TGS /E CNMB/2E/KIT 1 2 1 1 CNMB/3E/KIT 1 2 1 1 CNMB/4E/KIT 1 2 1 1 CNMB/5E/KIT 1 2 1 1 CNMB/6E/KIT 1 4* 2* 1 CNMB/9E/KIT 1 6* 3* 1 D I N R A I L E N C LOS U R E S CNMB/2 CNMB/3 C N M B /6 * CNMB/9* CNMB/12* 4 8 12 16 20 12 12 12 CTBP0305 PCB terminal Rising clamp 4 8 12 16 20 12 12 12 CTBP92VD/R Pluggable terminal female Rising clamp 4 8 12 16 20 12 12 12 CTBP93VD Pluggable terminal male 4 8 12 16 20 12 12 12 CTBP0308 PCB terminal Rising clamp 4 8 12 16 20 12 12 12 CTBP92VE/R Pluggable terminal Rising clamp 4 8 12 16 20 12 12 12 CTBP93VE Pluggable terminal male 4 8 12 16 20 12 12 12 CTBP5000 PCB terminal Wire protector 3 6 9 12 15 9 9 9 CTBP0500 PCB terminal Rising clamp 3 6 9 12 15 9 9 9 CTBP1000 PCB terminal Wire protector 3 6 9 12 15 9 9 9 CTBP0100 PCB terminal Rising clamp 3 6 9 12 15 9 9 9 CTB7000 PCB terminal Rising clamp 3 6 9 12 15 9 9 9 CTBP92VG/R Pluggable terminal female Rising clamp 3 6 9 12 15 9 9 9 CTBP9300 Pluggable terminal male 3 6 9 12 15 9 9 9 CTBP0108 PCB terminal Rising clamp 3 6 9 12 15 9 9 9 CTBP0508 PCB terminal Rising clamp 3 6 9 12 15 9 9 9 CTBP0708 PCB terminal Rising clamp 3 6 9 12 15 9 9 9 CTBP92VJ/R Pluggable terminal female Rising clamp 3 6 9 12 15 9 9 9 CTBP9308 Pluggable terminal male 3 6 9 12 15 9 9 9 CTBP55VK PCB terminal Wire protector 2 4 6 8 10 6 6 6 CTBP07VK PCB terminal Rising clamp 2 4 6 8 10 6 6 6 CTBP0110 PCB terminal Rising clamp 2 4 6 8 10 6 6 6 9.5MM CTBP04VZ PCB terminal Rising clamp 0 3 5 6 8 5 5 5 CTB0609 PCB terminal Rising clamp 0 3 5 7 9 5 5 5 T E R M I N A L B LO C K PA R T N U M B E R C N M B /4 PITCH CNMB/5 CNMB/1 CTBP3051 PCB terminal Wire protector 1 0.1 6 M M C N M B T E R M I N A L B LO C K S E L E C T I O N CHART D I N R A I L E N C LOS U R E S 7. 5 M M 5.08MM 5MM 3.81MM 3.5MM NUMBER OF POLES Please note: size /6, /9 & /12 have the same sized terminal space as a size /3 housing and therefore use the same sized terminal blocks +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 397
CNMB/12/2
1. 物料型号:文档中列出了多种型号的塑料外壳,如CNMB/1至CNMB/12,以及不同配置的扩展模块和附件。
2. 器件简介:这些塑料外壳设计用于符合DIN 43880标准,采用快装模块化设计,便于组装和定制套件。
3. 引脚分配:文档提供了不同型号塑料外壳的引脚分配信息,包括水平和垂直PCB尺寸。
4. 参数特性:外壳采用UL94-V0阻燃聚碳酸酯材料制成,能够承载多达3个水平PCB或2个垂直PCB。
5. 功能详解:包括快装端盖选项以提供IP20级别的手指保护,以及可定制的端盖和端子保护。
6. 应用信息:外壳适用于多种应用,包括作为屏幕打印的前面板,以及用于标签和膜的固体顶部。
7. 封装信息:提供了不同颜色和材料的端盖选项,如透明红、烟熏透明和灰色。
CNMB/12/2 价格&库存
很抱歉,暂时无法提供与“CNMB/12/2”相匹配的价格&库存,您可以联系我们找货
CNMB/12/2
    • 1+169.63100
    库存:2
