CSTBP762H/3
CSTBP762H/3
    CAMDENBOSS
    CAMDENBOSS - CSTBP762H/3 - Wire-To-Board Terminal Block, 7.62 mm, 3 Ways, 28 AWG, 16 AWG, 1.3 mm², P...
CSTBP762H/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 7. 6 2 m m s c r e w l e s s t e r m i n a l b l o c k s 081 TERMINAL STRIPS Product overview Interlocking modules Easily breakable to desired number of poles Guided pin alignment Choice of vertical or horizontal cable entry Moulded in green UL94-V0 PA66 0.34-2.5mm2 cable (22-14AWG) US approved C 17.8mm 3 25.4mm CSTBP762V/4 4 33.0mm CSTBP762V/5 5 40.6mm CSTBP762V/6 6 48.3mm CSTBP762V/7 7 55.9mm CSTBP762V/8 8 63.5mm CSTBP762V/9 9 71.1mm CSTBP762V/10 10 78.7mm CSTBP762V/11 11 86.4mm CSTBP762V/12 12 94.0mm PA R T N O . POLES LENGTH CSTBP762H/2 2 17.8mm CSTBP762H/3 3 25.4mm CSTBP762H/4 4 33.0mm CSTBP762H/5 5 40.6mm CSTBP762H/6 6 48.3mm CSTBP762H/7 7 55.9mm CSTBP762H/8 8 63.5mm CSTBP762H/9 9 71.1mm CSTBP762H/10 10 78.7mm CSTBP762H/11 11 86.4mm CSTBP762H/12 12 94.0mm -40°C to +115°C Moulding UL94-V0 PA66 Pin/contact Tin plated brass Recommended PCB hole size 1.2mm 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS CSTBP762V 0.50 1.00 7.62 158 INTERFACE MODULES AND RELAY BASES 7.62 3.15 7.62x(N-1) 7.62x(N-1) 7.62xN 7.62 Ø1.20 Ø2.20 1.45 2 CSTBP762V/3 Operating temperature 095 WIRE TO BOARD CONNECTORS 10.50 CSTBP762V/2 500MΩ at DC500V 7.62 LENGTH AC2500V/1 min Insulation resistance 14.20 POLES 10A/300V Insulation withstand voltage 10.50 PA R T N O . Rating 13.55 • • • • • • • S P E C I F I C AT I O N PCB LAYOUT CSTBP762H 7.62 7.62 0.50 7.62x(N-1) 7.62x(N-1) 7.62 7.62 14.20 7.62xN Ø1.20 14.20 1.05 1.80 13.60 10.50 Ø2.20 PCB LAYOUT K E Y F E AT U R E S | Modular design CONNECT Dual row pins | Screwless actuated cage terminals +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 1 Vers 89
CSTBP762H/3 价格&库存
很抱歉,暂时无法提供与“CSTBP762H/3”相匹配的价格&库存,您可以联系我们找货
