CTB0102/2
CTB0102/2
    CAMDENBOSS
    Conn Terminal Block 2 POS 5mm Solder ST Thru-Hole 10A
CTB0102/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS ECONOMY RANGE 5mm pitch standard rising clamp terminal block Product overview CTB0102 • 2-12 pole interlocking • Professional rising clamp terminals • Moulded in green UL94-V0 flame retardant PA66 • 0.32-3.3 mm2 (22-12 AWG) • Guided pin alignment • approved S P E C I F I C AT I O N PA R T N O . POLES LENGTH Rating 10A/300V CTB0102/2 2 10mm Insulation resistance 5000MΩ/1000V CTB0102/3 3 15mm Withstand voltage AC1500V/1min CTB0102/4 4 20mm Contact resistance 20mΩ (max) CTB0102/5 5 25mm Working temperature -33°C to 120+°C CTB0102/6 6 30mm Mouldings UL94-V0 Flame retardant PA66 CTB0102/7 7 35mm Screw/torque M2.5 Steel, Nickel Plated 0.4Nm CTB0102/8 8 40mm Recommended PCB hole size ø1.5mm CTB0102/9 9 45mm CTB0102/10 10 50mm CTB0102/11 11 55mm CTB0102/12 12 60mm K E Y F E AT U R E S | Interlocking E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS U L 9 4 -V 0 PA m o u l d i n g | P r o f e s s i o n a l r i s i n g c l a m p 7 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CTB0102/2 价格&库存
很抱歉,暂时无法提供与“CTB0102/2”相匹配的价格&库存,您可以联系我们找货
