CTB0602/3
CTB0602/3
    CAMDENBOSS
    CAMDENBOSS - CTB0602/3 - Wire-To-Board Terminal Block, 10 mm, 3 Ways, 26 AWG, 16 AWG, 1.3 mm², Screw
CTB0602/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 10mm pitch low profile rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS CTB0602 • 2 and 3 pole double interlocking mechanism for increased strength • Professional rising clamp terminals • Low profile • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.4-1.3mm2 (26-16 AWG) • Guided pin alignment • C US approved 151 IP68 CONNECTORS INTERFACE MODULES AND RELAY BASES LENGTH CTB0602/2 2 15.2mm Dielectric strength ≥2kV CTB0602/3 3 25mm Insulation resistance 5000M Ω/1000V CTB0602/4 4 35mm Working temperature -33°C to +120°C CTB0602/5 5 45mm Moulding UL94-V0 flame retardant PA66 CTB0602/6 6 55mm Pin/terminal Tin plated brass CTB0602/7 7 65mm Wire clamp Nickel plated brass CTB0602/8 8 75mm Screw/torque M2.5 steel Ni plated CTB0602/9 9 85mm Recommended PCB hole size ø1.4mm CTB0602/10 10 95mm CTB0602/11 11 105mm CTB0602/12 12 115mm 8.1 10 0.9 K E Y F E AT U R E S | Professional rising clamp CONNECT Low profile | Double interlock mechanism 48 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 0.5 POLES 10A/300V 3.5 158 PA R T N O . Rating 10 S P E C I F I C AT I O N 4
CTB0602/3 价格&库存
很抱歉,暂时无法提供与“CTB0602/3”相匹配的价格&库存,您可以联系我们找货
