CTB0609/2
CTB0609/2
    CAMDENBOSS
    CAMDENBOSS - CTB0609/2 - Wire-To-Board Terminal Block, 10.16 mm, 2 Ways, 26 AWG, 16 AWG, 1.31 mm², S...
CTB0609/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 1 0.1 6 m m p i tc h l ow p ro f i l e r i s i n g clamp terminal blocks Product overview 081 TERMINAL STRIPS CTB0609 • • • • 2 to 12 pole interlocking Professional rising clamp terminals Low profile Moulded in green UL94-V0 flame retardant PA • Cable acceptance - 0.13-1.31mm2 (26-16 AWG) • Guided pin alignment • C US approved 100 CIRCULAR CONNECTORS PA R T N O . POLES LENGTH 10A/300V CTB0609/2 2 15.2mm Dielectric strength ≥2kV CTB0609/3 3 24.6mm Insulation resistance 5000M Ω/1000V CTB0609/4 4 34.76mm Working temperature -33°C to +120°C CTB0609/5 5 44.92mm Moulding UL94-V0 flame retardant PA66 CTB0609/6 6 55.08mm Pin/terminal Brass. tin plated CTB0609/7 7 65.24mm Wire clamp Nickel plated brass CTB0609/8 8 75.4mm Screw/torque M2.5 steel nickel plated CTB0609/9 9 85.56mm CTB0609/10 10 95.72mm CTB0609/11 11 105.88mm CTB0609/12 12 116.04mm Recommended PCB hole size ø1.3mm 158 8.3 2.5x2.1 INTERFACE MODULES AND RELAY BASES 10.16 10.1 Rating 151 IP68 CONNECTORS 0.5 4.1 S P E C I F I C AT I O N 095 WIRE TO BOARD CONNECTORS 0.8 4.55 K E Y F E AT U R E S CONNECT 2 t o 1 2 p o l e i n t e r l o c k i n g | D o u b l e i n t e r l o c k m e c h a n i s m | P ro f e s s i o n a l r i s i n g c l a m p +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 55
CTB0609/2 价格&库存
很抱歉,暂时无法提供与“CTB0609/2”相匹配的价格&库存,您可以联系我们找货
