CTB5050/5
CTB5050/5
    CAMDENBOSS
CTB5050/5 数据手册
PCB Terminal blocks 5mm Pitch Low Profile Screw Terminal • • • • • • • • • • 2 & 3 pole interlocking 4-12 pole solid block end stackable Test probe facility Moulded in grey UL94-V0 flame retardant PC Wire protector terminals 0.5-1.5mm2 (30-14AWG) solid cable 0.5-1.0mm2 (30-14AWG) stranded cable Guided pin alignment Anti solder wicking terminal , , , approved PCb terminal blocks Specification Rating CTB5000 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Wire protector Screw/torque Recommended PCB hole size Type No. CTB5000/2 CTB5000/3 CTB5000/4 CTB5000/5 CTB5000/6 CTB5000/7 Poles 2 3 4 5 6 7 Length 10mm 15mm 20mm 25mm 30mm 35mm CTB5000/8 CTB5000/9 CTB5000/10 CTB5000/11 CTB5000/12 8 9 10 11 12 40mm 45mm 50mm 55mm 60mm 29A/250V UL=14A/300V, VDE&IMQ=13.5A/250V ≥2kV 4kV 85°C UL94-V0 flame retardant PC Tinned, nickel plated brass Tin plated phosphor bronze M2.5 steel zinc plated, 0.5Nm ø1.1mm 2 & 3 pole interlocking 4-12 pole solid block Test probe facility 90° Mounting Moulded in grey UL94-V0 flame retardant PC Wire protector terminals 0.5-1.5mm2 (30-14AWG) solid cable 0.5-1.0mm2 (30-14AWG) stranded cable  Anti solder wicking terminal Guided pin alignment  , , , approved Miniature switches limit & Safety switches control products Type No. CTB5050/2 CTB5050/3 CTB5050/4 CTB5050/5 CTB5050/6 CTB5050/7 CTB5050/8 CTB5050/9 CTB5050/10 CTB5050/11 CTB5050/12 Interface modules & supports Specification Rating CTB5050 29A/250V UL=14A/300V, VDE&IMQ=13.5A/250V ≥2kV Dielectric strength 4kV Impulse withstand voltage 85°C Working temperature UL94-V0 flame retardant PC Moulding Tinned, nickel plated brass Pin/terminal Tin plated phosphor bronze Wire protector M2.5 steel zinc plated, 0.5Nm Screw/torque Recommended PCB hole size ø1.1mm Poles 2 3 4 5 6 7 8 9 10 11 12 Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm fuses & Fuseholders LEDs & Indicators 5mm Pitch Low Profile 90˚ Screw Terminal • • • • • • • • • • • Interconnection relay bases enclosures batteries transformers For other dimensions see CTB5000
 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 9 Ver 1.0 ELEC T RON IC S & ENC LOSURES
CTB5050/5 价格&库存
很抱歉,暂时无法提供与“CTB5050/5”相匹配的价格&库存,您可以联系我们找货
