PCB TERMINAL BLOCKS
5mm Pitch Low Profile Screw Terminal Blocks
2 & 3 pole interlocking
4-12 pole solid block
end stackable
Test probe facility
Moulded in grey UL94-V0
flame retardant PC
Wire protector terminals
0.5-1.5mm2 (30-14AWG)
solid cable
0.5-1.0mm2 (30-14AWG)
stranded cable
Guided pin alignment
Anti solder wicking terminal
approved
SPECIFICATION
Rating
CTB5000
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Wire protector
Screw/torque
Recommended PCB hole size
PCB
TERMINAL
BLOCKS
13.5A/250V
UL=14A/300V, VDE&IMQ=13.5A/250V
≥2kV
4kV
85°C
UL94-V0 flame retardant PC
Tinned, nickel plated brass
Tin plated phosphor bronze
M2.5 steel zinc plated, 0.4Nm
ø1.1mm
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
TYPE NO.
CTB5000/2
CTB5000/3
CTB5000/4
CTB5000/5
CTB5000/6
CTB5000/7
CTB5000/8
CTB5000/9
CTB5000/10
CTB5000/11
CTB5000/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
5mm Pitch Low Profile 90˚ Screw Terminal Blocks
Test probe facility
90° Mounting
flame retardant PC
solid cable
stranded cable
approved
SPECIFICATION
Rating
CTB5050
Dielectric strength
Working temperature
Moulding
Pin/terminal
Wire protector
Screw/torque
TYPE NO.
CTB5050/2
CTB5050/3
CTB5050/4
CTB5050/5
CTB5050/6
CTB5050/7
CTB5050/8
CTB5050/9
CTB5050/10
CTB5050/11
CTB5050/12
+44 (0)1638 716101
+44 (0)1638 716101
info@camdenboss.com
info@camdenboss.com
www.camdenboss.com
www.camdenboss.com
POLES
2
3
4
5
6
7
8
9
10
11
12
INTERFACE
MODULES &
SUPPORTS
13.5A/250V
≥2kV
4kV
85°C
ø1.1mm
DIN RAIL
ENCLOSURES
BATTERIES
LENGTH
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
Ver 1.1
We operate a constant improvement policy,
products
are subject
to change without
Weour
operate
a constant
improvement
policy, notice. Ver 1.0
our products are subject to change without notice.
RELAY
BASES
SOLAR
TRANSPANELS
FORMERS
TRANSSOLAR
FORMERS
PANELS
13
EL EC T RO N IC S & ENC LOSURES
很抱歉,暂时无法提供与“CTB5050/6”相匹配的价格&库存,您可以联系我们找货
